Fan clutch bolts #3219111
03/08/24 02:55 PM
03/08/24 02:55 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Finally got my new fan clutch and plan on installing it and the fan this weekend. I have been reading posts here and elsewhere about what bolts to use. I was planning on using 5/16-18 x 3/4" factory bolts that have the captive washers on them that i have in my bolt collection. Some of the things I've read refer to place bolts for the clutch to the water pump and studs/nuts with conical washers for the fan to the clutch. While I recognized the head design, I never heard the term place bolt before. Are they really necessary? I have had about 30 Mopars over the years and don't recall ever seeing or using place bolts on any of my fan clutches before. I've always just used the factory bolts with the captive washers. As far as the fan to the clutch, I have had them with both bolts and studs.
Re: Fan clutch bolts [Re: 6PAX] #3219130
03/08/24 05:39 PM
03/08/24 05:39 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I just took a fan clutch off of a very original car that hadn't been started in 28 years this weekend and yes it had place bolts. Like it should. Factory bolts with SEMS washers (captured) are sexy but I've never seen any there.
2011 Drag Pak Challenger
Re: Fan clutch bolts [Re: rickseeman] #3219131
03/08/24 05:46 PM
03/08/24 05:46 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Maybe I should clarify. I didn't remove the clutch from the fan, I took them both off at once. The bolts holding the fan on were the place bolts.
Re: Fan clutch bolts [Re: rickseeman] #3219147
03/08/24 07:00 PM
03/08/24 07:00 PM
Cab_Burge Online work
Cab_Burge  Online Work
What is a "place bolt"?
Pictures please luck
Re: Fan clutch bolts [Re: Cab_Burge] #3219151
03/08/24 07:49 PM
03/08/24 07:49 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Slotted head.
Re: Fan clutch bolts [Re: 6PAX] #3219161
03/08/24 09:03 PM
03/08/24 09:03 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
And notice that undercut under the head. That's part of the magic. I'll try to find that sheet about place bolts. They're sexy. But then again I like bolts.
Re: Fan clutch bolts [Re: rickseeman] #3219165
03/08/24 09:18 PM
03/08/24 09:18 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Click here to find out what a place bolt is, they're sexy.
https://www.earnestmachine.com/sites/default/files/products/imported/BHP.pdf
Re: Fan clutch bolts [Re: rickseeman] #3219319
03/09/24 03:42 PM
03/09/24 03:42 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Right or wrong, these are the bolts that I am using.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
