carb on a 6.4 #3213357
02/13/24 10:06 PM
02/13/24 10:06 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Is there a way to do it without removing the crank to switch the tone wheel? Maybe an update to the MSD hemi 6 now that VVT has been out for 15 years or some kind of adapter? What about another way all together to fire the coils?
Re: carb on a 6.4 [Re: HotRodDave] #3213448
02/14/24 10:53 AM
02/14/24 10:53 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
You could use this system to run ignition only. This same system can also do the fuel, but wouldn't be a big deal to just run ignition.
https://www.efisource.com/wp/shop/microsquirt-plug-and-play-for-2009-g3-hemi/
At that point it costs more to go with a carb, just run the EFI with this basic controller.
68 Barracuda Formula S 340
Re: carb on a 6.4 [Re: Bad340fish] #3215055
02/21/24 02:41 AM
02/21/24 02:41 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Re: carb on a 6.4 [Re: cudadoug] #3215345
02/22/24 12:24 PM
02/22/24 12:24 PM
Kalispell Mt.
Kalispell Mt.
I never heard back so that is what we ordered, it really isn't more expensive than the msd considering it comes with the harness
Re: carb on a 6.4 [Re: cudadoug] #3215348
02/22/24 12:32 PM
02/22/24 12:32 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
That MMX setup does look nice,plus it fits all years of the G3 Hemi.
Re: carb on a 6.4 [Re: RTSrunner] #3215549
02/23/24 09:39 AM
02/23/24 09:39 AM
BDW Offline
BDW  Offline
Out of curiosity, what is the advantage of carb vs EFI?
Re: carb on a 6.4 [Re: BDW] #3215558
02/23/24 10:15 AM
02/23/24 10:15 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Not a 6.4, but I had a buddy that put a 5.7L in his 68 Dart with a carb. He has since sold it. However, it ran pretty good. I think it went the best of like 12:30's and all stock, other than what it took to do the swap into his car.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: carb on a 6.4 [Re: BDW] #3215656
02/23/24 06:27 PM
02/23/24 06:27 PM
Kalispell Mt.
Kalispell Mt.
Simpler, cheaper, harder to start....
Re: carb on a 6.4 [Re: HotRodDave] #3215726
02/23/24 11:52 PM
02/23/24 11:52 PM
montana
BANDIT Offline
BANDIT  Offline
montana
Would there be a way to run a stock 04 5-speed auto with the MMX system? Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: carb on a 6.4 [Re: HotRodDave] #3215770
02/24/24 10:34 AM
02/24/24 10:34 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Easier fuel system and wiring plus if you are doing a big project one less thing to worry about.
It has gotten easier to use EFI so I might use it on my next project.
Re: carb on a 6.4 [Re: BANDIT] #3216269
02/26/24 10:03 AM
02/26/24 10:03 AM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
sound German engineering has a stand alone harness for the nag1 5 speed
Re: carb on a 6.4 [Re: w2stroker] #3216976
02/29/24 07:38 AM
02/29/24 07:38 AM
BDW Offline
BDW  Offline
Looking at the cost of that standalone controller, I'm not seeing a cost savings?
Add up the controller, manifold and carb, it's the same or probably higher than the EFI?
I guess if you already have a carb, but still don't see the upside?
There is a cost for the EFI tank, so maybe that's the reason.
Re: carb on a 6.4 [Re: BDW] #3216985
02/29/24 09:47 AM
02/29/24 09:47 AM
MD
MD
Pretty much the same cost starting from scratch and buying new but who does that?
I had a carb, pump and fuel cell.
Re: carb on a 6.4 [Re: RTSE4ME] #3217018
02/29/24 12:33 PM
02/29/24 12:33 PM
Kalispell Mt.
Kalispell Mt.
EFI guys are LYING OUT THEIR BUTT when they say it is the same cost to go to EFI if you are buying new. There is a computer either way and the carb one is cheaper, got to buy injectors and a carb is cheaper than new injectors unless your buying the flavor of the week custom carb, the fuel lines are cheaper especially if your EFI needs a return, EFI needs fuel rails that are usually extra, the carb fuel pump is cheaper, the fuel tank is cheaper, the wiring is far easier and if your paying someone to do it then it is cheaper, no weldin in O2s for a carb unless you want them, no buying O2s... and none of this is using parts you have laying around, his car already has a nice fuel tank and fuel lines for a carb so he could literally buy a carb, intake, and ignition controller and that is it.
Re: carb on a 6.4 [Re: HotRodDave] #3217354
03/01/24 07:51 PM
03/01/24 07:51 PM
cudadoug Offline
cudadoug  Offline
The carb vs. EDI comparison isn't clear for me at this point. That said, I already have a well dialed in carb, fresh Holley black pump and new plumbing already in the car.
I have the Prefix intake so I am intrigued by a possible 4150 style EFI throttle body, but we'll see.
Re: carb on a 6.4 [Re: HotRodDave] #3217948
03/04/24 10:06 AM
03/04/24 10:06 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Dave you’re supposed to get all that stuff (less the fuel pump) with the donor engine!
I don’t know all of the intakes available now and what you’re gonna run, but that 6.4 intake with the variable runner length / flapper valve might make a big difference in low end torque and top end power.
Re: carb on a 6.4 [Re: GTX MATT] #3218496
03/05/24 10:57 PM
03/05/24 10:57 PM
IL
furious70 Offline
furious70  Offline
IL
Completely agree here. plenty of dyno tests showing the 5.7 truck intake is good and comes fully loaded.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: carb on a 6.4 [Re: GTX MATT] #3219962
03/12/24 01:01 PM
03/12/24 01:01 PM
Kalispell Mt.
Kalispell Mt.
If you get to count injectors and intake in the price that may or may not come with an engine than I get to use a 750 HP carbulator I have laying around for price comparison...
