Page 1 of 3 1 2 3
type F transmission fluid ?? #3217471
03/02/24 01:53 PM
03/02/24 01:53 PM
moparx Offline OP
moparx  Offline OP
around here, there doesn't seem to be a source for type F fluid, not even at the two local wally worlds.
on line, it seems that stuff goes for $7.00-9.00 per quart. eek
so what is the go to stuff these days ?
hydraulic fluid or ????
i really don't want to use type 4 or generic/universal ATF.
beer
Re: type F transmission fluid ?? [Re: moparx] #3217487
03/02/24 02:23 PM
03/02/24 02:23 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I get amalie type f on Amazon
Re: type F transmission fluid ?? [Re: rickraw] #3217492
03/02/24 02:45 PM
03/02/24 02:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have switched to Transynd fluid in all my stuff. BEen running it for a couple of years and still looks new. It is the Allison trans fluid used in Medium trucks, motohomes etc.
Re: type F transmission fluid ?? [Re: moparx] #3217521
03/02/24 05:25 PM
03/02/24 05:25 PM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree....it's getting hard to find here(St.Lou)it's hit and mis here. shruggy
Re: type F transmission fluid ?? [Re: racerx] #3217525
03/02/24 05:38 PM
03/02/24 05:38 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Rural king had a lot of it last time I was there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: type F transmission fluid ?? [Re: Al_Alguire] #3217526
03/02/24 05:39 PM
03/02/24 05:39 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Quote
Application
Castrol TranSynd can be recommended for all vehicles calling for Dexron III/Mercon or Allison TES 295 and TES 468 ATF's
suitable for bus and refuse vehicles with automatic transmissions.
Garbage trucks?
That TranSynd is about $50 /gal. Almost triple the cost of Dexron III/Mercon that it replaces. Does it say B&M Trick Shift on it?
Re: type F transmission fluid ?? [Re: GomangoCuda] #3217529
03/02/24 05:51 PM
03/02/24 05:51 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Advance has it ( by me anyhow ) $9.79 a quart in stock , I just bought some a few weeks ago.. they had to order it for me last time as they didn't stock it .
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: type F transmission fluid ?? [Re: Al_Alguire] #3217536
03/02/24 06:18 PM
03/02/24 06:18 PM
Kirkland, Washington
Pacnorthcuda Offline
It’s also used in class 8 big rigs, I bought many thousands of gallons during my time building Kenworths.
Re: type F transmission fluid ?? [Re: Pacnorthcuda] #3217548
03/02/24 07:30 PM
03/02/24 07:30 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Rockauto has it, shipping cost would depend on where you are. There aren't any savings shipping a lot of stuff into Canada, I know that.
Re: type F transmission fluid ?? [Re: Uberpube] #3217576
03/02/24 09:00 PM
03/02/24 09:00 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
O Reilly’s always have it around here. Never had an issue getting it other places either.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: type F transmission fluid ?? [Re: Al_Alguire] #3217580
03/02/24 09:11 PM
03/02/24 09:11 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
That’s all I use.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: type F transmission fluid ?? [Re: BloFish] #3217639
03/03/24 09:10 AM
03/03/24 09:10 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use the Walmart brand type F. The store usually has some in stock if not I order it from Walmart online and have it delivered.
68 Barracuda Formula S 340
Re: type F transmission fluid ?? [Re: Al_Alguire] #3217646
03/03/24 09:35 AM
03/03/24 09:35 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Ditto, That stuff is worth every penny.
Without Data, you’re just another guy with an opinion.
Re: type F transmission fluid ?? [Re: sr4440] #3217697
03/03/24 12:18 PM
03/03/24 12:18 PM
PA
moparacer Offline
moparacer  Offline
PA
You all can take it for what it is worth, but I moved away from Type F when it started getting scarce and expensive in my Glide and went to the Valvoline universal full synthetic you can buy at any Walmart for $20-25 a gallon.
2860 lbs 800+ hp and beat for 3 years at 200 passes a year, and when I pull the trans apart to look it over this week I will reuse the band and clutches. Which are a lot older than that.
Works great in my old Duster with a 904 in it too.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: type F transmission fluid ?? [Re: sr4440] #3217700
03/03/24 12:23 PM
03/03/24 12:23 PM
moparx Offline OP
moparx  Offline OP
thanks fellows ! bow
i never thought about rock auto.
i'll have to check wally world on line and see about that as well.
i was thinking about using a type of hydraulic fluid, but i didn't get that far.
looks like i have homework to do..........
beer
Re: type F transmission fluid ?? [Re: Bad340fish] #3217713
03/03/24 01:04 PM
03/03/24 01:04 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I was just getting ready post this.
'63 Dodge 330
11.19 @ 121 mph
Re: type F transmission fluid ?? [Re: GY3] #3217726
03/03/24 02:01 PM
03/03/24 02:01 PM
PA
moparacer Offline
moparacer  Offline
PA
My Wally world and parts stores in my area always seem to keep a few quarts of F on hand and everytime I had to run all over creation gathering up enough.
Re: type F transmission fluid ?? [Re: moparacer] #3217765
03/03/24 03:57 PM
03/03/24 03:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you are stuck on Type F Walmart generall always has it.
As for the Transynd it keeps my stuff much cooler than anything else I have ever used. And if you run a car on a stop they tend to put some heat in the trans. If oyu want to run B&M colored type F go for it. Ill stick with what has worked best for me. And I have been through a lot of cars and combos over the years.
Re: type F transmission fluid ?? [Re: Al_Alguire] #3217802
03/03/24 06:15 PM
03/03/24 06:15 PM
GomangoCuda Offline
GomangoCuda  Offline
When I mentioned the B&M blue Stuff i was being sarcastic. Guess I should have put a smiley on there. Nobody I know has used that snake oil for about 50 years.
If the TranSynd runs significantly cooler then that would be worth paying for. Does it affect stall speed, et or consistency?
Re: type F transmission fluid ?? [Re: GomangoCuda] #3217879
03/03/24 10:45 PM
03/03/24 10:45 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Type F
$4.49 at my local Fleet Farm
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Page 1 of 3 1 2 3
