How many 1/4 mile passes do you get with 5 gals of gas? #3217119
02/29/24 06:15 PM
02/29/24 06:15 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Trying to figure how much fuel to take with me out west.
Curious to know on 9 to 10 second cars with 500 inch motors running on gasoline how many passes you AVERAGE on a 5 gallon tank. Looking for cars that also weigh over 3300 LBS.
THANKS!!!
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: mercman1] #3217121
02/29/24 06:21 PM
02/29/24 06:21 PM
pa
gregcharger72 Online happy
gregcharger72  Online Happy
pa
I can get about 10 runs or so before I add more fuel. 3600 lbs car mid 10 ets. 470 ci.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: gregcharger72] #3217133
02/29/24 07:15 PM
02/29/24 07:15 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I don't know. I always top the cell off after each run for more weight over the rear tires. I have a 10 gallon cell and can usually drive wherever and back on the one tank.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: 6PKRTSE] #3217136
02/29/24 07:26 PM
02/29/24 07:26 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I normally look at around 8 passes @ about 20litres (5 US gallons)
505ci @ 3800ish
For some this might change dependent on RPM .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: tex013] #3217145
02/29/24 08:16 PM
02/29/24 08:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Normal tracks about ten 9.0 1/4 mile runs driving to the staging lanes and back to the pits. Morning warm up will add to that figure. Real long shut down like Indy uses a bit more.
Doug
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: dvw] #3217155
02/29/24 08:56 PM
02/29/24 08:56 PM
birdtracker Offline
birdtracker  Offline
3. Birdtracker
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: mercman1] #3217215
03/01/24 09:38 AM
03/01/24 09:38 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
7 1/4 mile passes out of a 20 litre jerry can. 580ci, 4023lb, mid 9's. The 655ci motor was 5 passes out of a can. Driven to the start and back to the pit.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: Tig] #3217287
03/01/24 02:19 PM
03/01/24 02:19 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Use WAY more driving around and warm ups than actually making a pass. I use a gallon or so to make a run from pit to pit. I use more warming it up in the morning.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: Tig] #3217288
03/01/24 02:21 PM
03/01/24 02:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
It not sure I would carry fuel across state lines “out west”. DOT guys frown on that and with all the dangers of carrying fuel on a long distance I’d buy it at the track.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: cudaman1969] #3217291
03/01/24 03:04 PM
03/01/24 03:04 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Race fuel at track in Vegas...$25 per gallon. AV gas in Okeechobee FL yesterday...$5.99 per gallon
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: mercman1] #3217313
03/01/24 04:50 PM
03/01/24 04:50 PM
What length track, 1/8 or 1/4 mile, what tranny, 2 speed or 3 speed?
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: mercman1] #3217329
03/01/24 06:29 PM
03/01/24 06:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
$25 you must be running the good stuff, I pay less for Q16 here. There are cheaper option for fuel here for sure. The track only supplies VP. But we have Sonoco and Torco readily available as well.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: Cab_Burge] #3217339
03/01/24 06:56 PM
03/01/24 06:56 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Title says 1/4 mile passes! Dont need to know to the drop so 2 or 3 speed won't really matter much.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: Al_Alguire] #3217341
03/01/24 07:06 PM
03/01/24 07:06 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Al you are correct. Not being a local or having much spare time, I did buy my fuel at the track last year and it was Q16. Bringing my cars this year and they are set up to run on cheap stuff. I've seen no difference in ET between VP 110 and AV gas. So far 9.64 at 138 with a 1.28 60 ft. Motor is a stock block 520, Stock Trick Flow heads, .640ish lift on cam at 12.4 compression.
I've found out you can haul upto 110 gals of fuel with out special permits. Hell, my boat hold more than that and never heard of trailer boats being pulled over.
Thanks to all those that replied. I'm guessing worse case is about 7 passes and best case is 10.
Re: How many 1/4 mile passes do you get with 5 gals of gas? [Re: mercman1] #3217343
03/01/24 07:08 PM
03/01/24 07:08 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Good deal..Would be great to meet you but I always seem to be busy at that race and I think this year will be even more so ...But Ill try to find you. Saw you while parking people but just didn't have time to stop and say hello.
