Shock and leaf spring recommendation for my 69 GTS #3216250
02/26/24 07:37 AM
02/26/24 07:37 AM
tboomer Offline OP
tboomer  Offline OP
I want to replace my air shocks and sagging leaf springs on my 69 GTS 340. The car is street driven and will see no track time. Looking for suggestions without breaking the bank! Thanks! Ted wave
Re: Shock and leaf spring recommendation for my 69 GTS [Re: tboomer] #3216266
02/26/24 09:41 AM
02/26/24 09:41 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I run SS springs I get from Mancini on my 69 Dart...
I also have leaf spring sliders in the rear...
The front perches are flipped upside down (raising the hole in the body) so the arch doesn't make it set too high...
The 72 Duster...65 Coronet and 70 Satellite also have them...no issues ever...
...FAFO...
Re: Shock and leaf spring recommendation for my 69 GTS [Re: skicker] #3216291
02/26/24 10:56 AM
02/26/24 10:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can you post a picture of the sliders installed in the car ?
Re: Shock and leaf spring recommendation for my 69 GTS [Re: JohnRR] #3216293
02/26/24 11:01 AM
02/26/24 11:01 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have had my originals re-arched at Spring Align, have one not to far from my house. I always use original parts when possible... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Shock and leaf spring recommendation for my 69 GTS [Re: Rhinodart] #3216321
02/26/24 01:01 PM
02/26/24 01:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ted -
Have originals re-arched, or call ESPO and get a set, maybe +1" - and for street shocks, I've been OK with the basic Monroes or whatever, oil-filled.
KYBs were fine on my Z28 "canyon car", but a lot of guys here say they're too stiff for Mopars.
I'm surprised at how low Skicker's Dart sits on SS springs - looks stock.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: topside] #3216331
02/26/24 01:19 PM
02/26/24 01:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by topside
Ted -
I was thinking the same thing.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: JohnRR] #3216346
02/26/24 01:53 PM
02/26/24 01:53 PM
tboomer Offline OP
tboomer  Offline OP
Thanks guys! Rhino--Check your pms. Ol Skickers car looks nice. I have American aluminum slots to put on my car but need to get the sagging springs and air shocks taken care of. What is the cost to re-arch the springs compared to new replacements?? wave
Re: Shock and leaf spring recommendation for my 69 GTS [Re: tboomer] #3216358
02/26/24 02:25 PM
02/26/24 02:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cost for re-arching varies: check locally.
There's a place in Spokane (Pohl Spring) that wanted $400/pair for that 3 years ago - only game in town, and they're greedy - but I've heard of $150-$200/pair in other areas.
Should be something in Archives on the topic.
Last set I bought from ESPO was cheaper than re-arching in Spokane, by a bunch, and the car got upgraded Hemi T-bars & then rear springs.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: JohnRR] #3216442
02/26/24 08:04 PM
02/26/24 08:04 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Evidently I don't have any of them in the 69...
These are pictures from the install in the 72 Duster...
The 69 Dart was done 1st and then the Duster was done the same way a few years later...
Last picture is of the spring hanger flipped upside down...
...FAFO...
Re: Shock and leaf spring recommendation for my 69 GTS [Re: skicker] #3216443
02/26/24 08:11 PM
02/26/24 08:11 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
This is the pic showing how much the front hanger was moved rearward...
This was done to run the 30" tall tires without cutting the front of the 1/4 panels...
The rear in the Duster is a 65 B body rear with a 9.5" wide rear wheel that has 5.5" of back space...
These wheels and tires are off of my 70 Satellite...Tires are 275/60/17's and measure right at 30" tall...
They were robbed from my car as you can see in the background of the 3rd pic...
They were used for mockup so that if he ever wanted a 9.00 x 30.0 slick he could run one...
...FAFO...
Re: Shock and leaf spring recommendation for my 69 GTS [Re: tboomer] #3216455
02/26/24 09:01 PM
02/26/24 09:01 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
no track time at all then there is no need for SS springs.. call espo ( https://www.springsnthings.com/ ) and get the height ya want. eaton senns a damn nice spring beyt they are more expensive.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Shock and leaf spring recommendation for my 69 GTS [Re: abodyjoe] #3216464
02/26/24 09:31 PM
02/26/24 09:31 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yes, on the Eaton springs. The 340 cars came with one more spring than the slant 6 and 318 cars did I think. Should have 6 leafs per side instead of the normal 5???
Re: Shock and leaf spring recommendation for my 69 GTS [Re: Neil] #3216580
02/27/24 12:39 PM
02/27/24 12:39 PM
moparx Offline
moparx  Offline
if it were my car, i would opt for new springs, or add a leaf or two to your current spring packs.
just my opinion. your mileage will vary.
beer
Re: Shock and leaf spring recommendation for my 69 GTS [Re: moparx] #3216732
02/27/24 11:39 PM
02/27/24 11:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
3x or 4 x on Espo. been using laura's springs on customers cars for over 20 years, never a problem.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: TJP] #3216750
02/28/24 05:06 AM
02/28/24 05:06 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My '69 Barracuda 340 developed rear wheel hop on hard acceleration only a few years from new. Maybe the rear was sagging also, but I didn't measure it. Had the springs re-arched, and the shop also added one more long leaf for a total of 7 each side. This fixed the wheel hop, and the rear sat maybe 1" higher than spec, which I liked.
Today, 50 years later, the springs are doing fine and still sitting about 1" high. I suspect that the extra leaves by themselves is mostly what fixed the problem, and that the re-arching didn't help that much.
My recommendation for sagging rear springs is to get a pair of used 2 1/2" wide leaves slightly shorter than the spring eye to spring eye distance, thickness the same or slightly thicker, redrill the center hole as necessary with a carbide drill, re-assemble with new pure, non-magnetic zinc interleaves (don't buy fake, magnetic galvanized steel interleaves) and new clamps, and see if the problem is fixed. If so, the cost of re-arching is saved. If not, then get the assemblies re-arched along with the extra leaves.
But be sure the re-arching shop doesn't throw away your pure zinc interleaves like my shop did.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: kentj340] #3216751
02/28/24 05:14 AM
02/28/24 05:14 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Restored springs after sandblast, colored with dilute gun blue, since full strength is too black, and coated with RPM wax. Note the second leaf down is the additional leaf, making a total of 7. In this case, the extra leaf was not drilled on the ends for the plastic sliders, but should have been.
Also note new pure zinc interleaves at the center bolt, as original.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: kentj340] #3216754
02/28/24 06:33 AM
02/28/24 06:33 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
For what it's worth I had a set of springs De Arched in Sept 2023. The cost was $170 to take 5" out of my 1995 Dakota leaf springs. Maybe the cost is similar to Re Arch.
Keep old mopars alive.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: tboomer] #3216768
02/28/24 10:13 AM
02/28/24 10:13 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
Usually SS springs jack the car up way high. I used Mancini Extra Heavy Duty springs in my Dart. Stock hangers. Offset shackle. Calvert adjustable rear shocks. Calvert 90/10 shocks up front. Rides nice. I think sits nice. Launches straight and hooks up at track.
Re: Shock and leaf spring recommendation for my 69 GTS [Re: TJP] #3216850
02/28/24 04:22 PM
02/28/24 04:22 PM
tboomer Offline OP
tboomer  Offline OP
I talked to Laura this morning. Very helpful. They have a 6 week lead time on the springs. wave
Re: Shock and leaf spring recommendation for my 69 GTS [Re: tboomer] #3216930
02/28/24 10:08 PM
02/28/24 10:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Some things are worth waiting for wink beer
