Fuel pump for E85
#3214397
02/18/24 04:50 PM
02/18/24 04:50 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm doing the switch to E85 this year and I'm changing a few things on my fuel system like pump,filter,lines,regulator etc... Now I know people out there say I don't need to change anything and then there is the camp that says change it all. My current system is a Holley blue with a Quick Fuel dead head regulator. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Fuel pump for E85
[Re: racerx]
#3214425
02/18/24 06:36 PM
02/18/24 06:36 PM
fourgearsavoy
Rittman Ohio
I have a couple of pumps I picked up over the past year that I thought might work for the increased volume. One is a BG 280 and a Holley HP 125. The Holley is supposed to be quiet with the new design rotors. This is a street/strip deal so I plan on using a bypass regulator with the increased volume of the pump. The BG seems a little overkill for my deal but as long as I have a return it shouldn't be an issue. Gus
[Re: Dabee]
#3214793
02/19/24 11:36 PM
02/19/24 11:36 PM
fourgearsavoy
Rittman Ohio
Thanks I was going to give it a go with the fuel system that is already on it with the AFR hooked up to dial the carb in. I don't like to change a bunch of fuel system parts all at once. I'm hoping the carb will be close as it was built Mark Sullens for a 500" Ford Fairlane about the same weight as my car. Gus
[Re: A39Coronet]
#3215147
02/21/24 02:43 PM
02/21/24 02:43 PM
Posts: 3,426 Dandridge TN
Dabee
Dandridge TN
I'd get a good compatible filter on both ends of the pump and let it eat until it gives you issues. I've wasted more money fixing problems that never existed than I care to share, and I'm sure I'm not alone. . Yes I team filters on both sides of pump. No
[Re: Dabee]
#3215247
02/21/24 09:23 PM
02/21/24 09:23 PM
fourgearsavoy
Rittman Ohio
I have a 100 micron before the pump and a 40 after the pump with my current system with -10 from the cell to the pump and 1/2" aluminum hard line up to the regulator. My plan is to run another 1/2" line for the return back to the tank from the bypass regulator. Thanks for the input I'm looking forward to the new fuel. I really don't see any downside to switching over. Gus
[Re: A/MP]
#3215394
02/22/24 03:00 PM
02/22/24 03:00 PM
fourgearsavoy
Rittman Ohio
So a few down sides- no paper element fuel filter material, SS only. Upgrade to better "RUBBER", that would be a teflon type line. and most importantly if you are using a carb, make heat fast in the motor. Cold temps 50*F or less will not let the alcohol vaporize fast enough to prevent cylinder wall wash down. I learned they facts when building a street 500HP set up. I solved many a start up and shut down issues by having a 1 gallon fuel cell with straight gasoline. Used it for startup and shut down. You can never get rid of the e85 by just shutting off the fuel pump and run the system dry. There is always fuel in the bowls afterwards. 10 to 15% fuel will slowly gunk the carb. e85 is worse. Sta- Bil and Lucas top cylinder/fuel injection cleaner in the fuel is a big help with maintenance issues with any alcohol/gasoline ratio. Hmm... so a small fuel cell, a couple of ball valves, another $150 in fittings for a secondary fuel system for cold start and clean shutdown. Sounds like a good idea that would add another $450 to the conversion. I have to look for a 3 port diverter valve so I don't have to plumb 2 valves that would save some dough and potential leak points. I keep my garage around 55 degrees all year but I do need to move it out when it's cold outside so it might be a worthwhile setup. Thanks for the tip. Gus
[Re: fourgearsavoy]
#3215674
02/23/24 08:03 PM
02/23/24 08:03 PM
fourgearsavoy
Rittman Ohio
Well there is a flaw with the extra fuel cell deal. It will work if you are using a deadhead regulator but the bypass will fill the E85 cell with regular fuel. I think I will just do the deal like I planned it out. Thanks Gus
