Page 3 of 3 1 2 3
Re: 440 six pack stock rods crank gram weight ? [Re: cudaman1969] #3203180
01/08/24 11:42 AM
01/08/24 11:42 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thanks cudaman, i seen a set of high conpression one's with a dome, i will remenber the piston hight for sure
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3203190
01/08/24 12:46 PM
01/08/24 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by B1Frank
Im using #452 heads for unleaded gas
Stock Iron or the Ebrock NHRA approved Alum ?
Re: 440 six pack stock rods crank gram weight ? [Re: JohnRR] #3203397
01/09/24 11:56 AM
01/09/24 11:56 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Im building the car like i woud have when i was #16 years old,...........mosty street...........strip car. 440 + 30 727 moved the rear back #11/2 inch's dana 60-4.10 some super stock tricks............LOL
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3203414
01/09/24 01:26 PM
01/09/24 01:26 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
the 2295 is probably the best option then.
Re: 440 six pack stock rods crank gram weight ? [Re: B1MAXX] #3203557
01/10/24 11:58 AM
01/10/24 11:58 AM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thanks brother, i will check them out, good luck this year with every thing !
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3205336
01/16/24 07:19 PM
01/16/24 07:19 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
Did you find a solution?
If you are interested in a complete short block that you could hear run before disassembly let me know.
I can send you a bunch of photos.
Re: 440 six pack stock rods crank gram weight ? [Re: Craig J] #3205857
01/18/24 12:15 PM
01/18/24 12:15 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
Thanks i will send you a PM..................Frank
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3213762
02/15/24 04:27 PM
02/15/24 04:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How did you make out on the 2295 search , I just came across these .
pistons on facebook
Re: 440 six pack stock rods crank gram weight ? [Re: JohnRR] #3213936
02/16/24 01:20 PM
02/16/24 01:20 PM
West Virginia
B1Frank Offline OP
B1Frank  Offline OP
West Virginia
I will check them out, the internet it not good here..............................to let you know my sister told me a could have her brand new steel crank 1967 .040 over short block.
Re: 440 six pack stock rods crank gram weight ? [Re: B1Frank] #3213960
02/16/24 03:00 PM
02/16/24 03:00 PM
Moving the rear end back is not good for traction, moving it forward is up wrench scope twocents
It is way better to trim the front edge of the rear wheel wells than it is to move the rearend back towards the gas tank, that will increase tire spin tsk shruggy twocents
Re: 440 six pack stock rods crank gram weight ? [Re: Cab_Burge] #3214017
02/16/24 08:10 PM
02/16/24 08:10 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
This is what I have for TRW/speed Pro pistons
Part# CH Weight Pin Wt CCs Deck Ht
L2266F 1.991 876 225 0 flat top .090
L2355F 2.061 872 225 -7cc .020
L2388F 1.926 819 225 0 flat top .155
L2295 2.029 817 250 13.1cc .140 dome .051
7025P 2.050 815 250 13.1cc .140 dome .051
Page 3 of 3 1 2 3
