carb on a 6.4
#3213357
02/13/24 10:06 PM
02/13/24 10:06 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Is there a way to do it without removing the crank to switch the tone wheel? Maybe an update to the MSD hemi 6 now that VVT has been out for 15 years or some kind of adapter? What about another way all together to fire the coils?
Re: carb on a 6.4
[Re: cudadoug]
#3215345
02/22/24 12:24 PM
02/22/24 12:24 PM
HotRodDave
Kalispell Mt.
I never heard back so that is what we ordered, it really isn't more expensive than the msd considering it comes with the harness
Re: carb on a 6.4
[Re: BDW]
#3215558
02/23/24 10:15 AM
02/23/24 10:15 AM
Posts: 4,585 Motor City
6PKRTSE
Motor City
Not a 6.4, but I had a buddy that put a 5.7L in his 68 Dart with a carb. He has since sold it. However, it ran pretty good. I think it went the best of like 12:30's and all stock, other than what it took to do the swap into his car.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: carb on a 6.4
[Re: BDW]
#3215656
02/23/24 06:27 PM
02/23/24 06:27 PM
HotRodDave
Kalispell Mt.
Simpler, cheaper, harder to start....
Re: carb on a 6.4
[Re: HotRodDave]
#3215726
02/23/24 11:52 PM
02/23/24 11:52 PM
Posts: 422 montana
BANDIT
montana
Would there be a way to run a stock 04 5-speed auto with the MMX system? Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
Re: carb on a 6.4
[Re: HotRodDave]
#3215770
02/24/24 10:34 AM
02/24/24 10:34 AM
Posts: 2,062 MD
RTSE4ME
MD
Simpler, cheaper, harder to start.... Easier fuel system and wiring plus if you are doing a big project one less thing to worry about. It has gotten easier to use EFI so I might use it on my next project.
Re: carb on a 6.4
[Re: RTSE4ME]
#3217018
02/29/24 12:33 PM
02/29/24 12:33 PM
HotRodDave
Kalispell Mt.
Pretty much the same cost starting from scratch and buying new but who does that? I had a carb, pump and fuel cell. EFI guys are LYING OUT THEIR BUTT when they say it is the same cost to go to EFI if you are buying new. There is a computer either way and the carb one is cheaper, got to buy injectors and a carb is cheaper than new injectors unless your buying the flavor of the week custom carb, the fuel lines are cheaper especially if your EFI needs a return, EFI needs fuel rails that are usually extra, the carb fuel pump is cheaper, the fuel tank is cheaper, the wiring is far easier and if your paying someone to do it then it is cheaper, no weldin in O2s for a carb unless you want them, no buying O2s... and none of this is using parts you have laying around, his car already has a nice fuel tank and fuel lines for a carb so he could literally buy a carb, intake, and ignition controller and that is it.
Re: carb on a 6.4
[Re: HotRodDave]
#3217948
03/04/24 10:06 AM
03/04/24 10:06 AM
Posts: 5,167 CT
GTX MATT
CT
Dave you’re supposed to get all that stuff (less the fuel pump) with the donor engine!
I don’t know all of the intakes available now and what you’re gonna run, but that 6.4 intake with the variable runner length / flapper valve might make a big difference in low end torque and top end power.
Re: carb on a 6.4
[Re: GTX MATT]
#3218496
03/05/24 10:57 PM
03/05/24 10:57 PM
Posts: 2,260 IL
furious70
IL
I don’t know all of the intakes available now and what you’re gonna run, but that 6.4 intake with the variable runner length / flapper valve might make a big difference in low end torque and top end power. Completely agree here. plenty of dyno tests showing the 5.7 truck intake is good and comes fully loaded.
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: carb on a 6.4
[Re: GTX MATT]
#3219962
03/12/24 01:01 PM
03/12/24 01:01 PM
HotRodDave
Kalispell Mt.
I don’t know all of the intakes available now and what you’re gonna run, but that 6.4 intake with the variable runner length / flapper valve might make a big difference in low end torque and top end power. If you get to count injectors and intake in the price that may or may not come with an engine than I get to use a 750 HP carbulator I have laying around for price comparison...
