Steering wheel repair tips #3213277
02/13/24 06:46 PM
02/13/24 06:46 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
65 wheel many cracks and 1/4” wide openings, what do y’all use to repair them? Epoxy, glass resin?
Re: Steering wheel repair tips [Re: cudaman1969] #3213301
02/13/24 08:26 PM
02/13/24 08:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I epoxied the wheel.on my 64 racecar. Sanded and primed . Painted with single stage urethane. It was beat up pretty good. 13 years later there are only a few small hairline cracks. But barely noticeable.
Doug
Re: Steering wheel repair tips [Re: dvw] #3213313
02/13/24 08:46 PM
02/13/24 08:46 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
https://youtu.be/4hchiLpoXWE?si=fFK2HFWYpjmQSuyy
Also saw another video where the guy used 2 part 3M panel bonding adhesive on a 68 Mustang steering wheel that was a disaster to start with. Only drawbacks there is the cost, and you have to have the applicator gun to use it.
Re: Steering wheel repair tips [Re: Neil] #3213358
02/13/24 10:08 PM
02/13/24 10:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I was shocked to see the guy in the video did not sand, clean or prep the wheel and cracks before starting. Adhesives 101A first chapter. twocents eek beer
Re: Steering wheel repair tips [Re: cudaman1969] #3213564
02/14/24 06:32 PM
02/14/24 06:32 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
JB Weld works great. Fill it, sand it, prime and paint. For the gap you can make a mold from a good part of the wheel with clay or latex. Then apply over the gap and fill with JB.
Re: Steering wheel repair tips [Re: cudaman1969] #3213768
02/15/24 05:13 PM
02/15/24 05:13 PM
Minn
SportF Offline
SportF  Offline
Minn
Don't use bondo, it only lasts 1 year.
Re: Steering wheel repair tips [Re: TJP] #3213770
02/15/24 05:39 PM
02/15/24 05:39 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Yes! prep is key to making it last. All the old cracks will likely be full of dirt, oils, and schmutz from your hands--use a dremel to grind the cracks so you are certain to be down to clean, solid, plastic.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Steering wheel repair tips [Re: wingman] #3213776
02/15/24 06:56 PM
02/15/24 06:56 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
PC-7 epoxy is what Eastwood sells in their kits.
You can get it at the hardware store much cheaper.
I did mine about 10 years ago and despite the extreme temps here in Kansas, it's holding up nicely.
I wish I had before pics because it was REALLY bad and missing large pieces. I used an angle grinder and dremel tool to get to clean metal and plastic.
One key to painting is bolt it to the engine stand so you can rotate it!
'63 Dodge 330
11.19 @ 121 mph
Re: Steering wheel repair tips [Re: wingman] #3213778
02/15/24 06:56 PM
02/15/24 06:56 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I have resorted/repaired a couple of steering wheels using https://www.eastwood.com/master-steering-wheel-repair-kit-w-instruc.html
All have held up well. Time, patience, cleaning and prep are the keys to success.
You can do it.
My Monster are real!
Living within your means makes life pretty easy.
Re: Steering wheel repair tips [Re: GY3] #3213780
02/15/24 06:57 PM
02/15/24 06:57 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
That is a beautiful interior..... bow drool
Re: Steering wheel repair tips [Re: 67vertman] #3213784
02/15/24 07:00 PM
02/15/24 07:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Thanks!
'63 Dodge 330
11.19 @ 121 mph
Re: Steering wheel repair tips [Re: GY3] #3213826
02/15/24 09:32 PM
02/15/24 09:32 PM
fredericksburg,va
fredericksburg,va
Thanks for tips, my plan is to cut off all the plastic in marked sections off the metal rim (rusty underneath) once clean I’ll epoxy each back on filling in the gaps. Finding the off blue paint will be the hardest imo
