Re: Steering wheel repair tips
[Re: dvw]
#3213313
02/13/24 08:46 PM
02/13/24 08:46 PM
Posts: 20,543 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
https://youtu.be/4hchiLpoXWE?si=fFK2HFWYpjmQSuyyAlso saw another video where the guy used 2 part 3M panel bonding adhesive on a 68 Mustang steering wheel that was a disaster to start with. Only drawbacks there is the cost, and you have to have the applicator gun to use it.
[Re: TJP]
#3213770
02/15/24 05:39 PM
02/15/24 05:39 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
https://youtu.be/4hchiLpoXWE?si=fFK2HFWYpjmQSuyyAlso saw another video where the guy used 2 part 3M panel bonding adhesive on a 68 Mustang steering wheel that was a disaster to start with. Only drawbacks there is the cost, and you have to have the applicator gun to use it. I was shocked to see the guy in the video did not sand, clean or prep the wheel and cracks before starting. Adhesives 101A first chapter. Yes! prep is key to making it last. All the old cracks will likely be full of dirt, oils, and schmutz from your hands--use a dremel to grind the cracks so you are certain to be down to clean, solid, plastic.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#3213776
02/15/24 06:56 PM
02/15/24 06:56 PM
Posts: 4,672 Wichita
GY3
Wichita
PC-7 epoxy is what Eastwood sells in their kits.
You can get it at the hardware store much cheaper.
I did mine about 10 years ago and despite the extreme temps here in Kansas, it's holding up nicely.
I wish I had before pics because it was REALLY bad and missing large pieces. I used an angle grinder and dremel tool to get to clean metal and plastic.
One key to painting is bolt it to the engine stand so you can rotate it!
