Draggy data recorders, what do they record? #3212897
02/11/24 10:22 PM
02/11/24 10:22 PM
Cab_Burge Offline OP
Any one on here use a draggy on your cars? If so what will, do, they record?
I itreid going on the website but no luck on getting any information at all shock confused
Thanks in advance: Cab
Re: Draggy data recorders, what do they record? [Re: Cab_Burge] #3212914
02/11/24 11:46 PM
02/11/24 11:46 PM
NY
challenger451ci Offline
NY
A Dragy can be setup to basically give you a timeslip. It'll give 60ft, 330ft, 1/8mi ET and mph as well as 1/4mi. We've checked one at the track with a car in the deep 5's and it was pretty accurate. It can also give you 0-60 and other mph ranges if you want. Pretty cool IMHO.
Re: Draggy data recorders, what do they record? [Re: challenger451ci] #3212939
02/12/24 01:13 AM
02/12/24 01:13 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
They also record elevation change over the run and a G meter.
'63 Dodge 330
11.19 @ 121 mph
Re: Draggy data recorders, what do they record? [Re: GY3] #3212952
02/12/24 02:42 AM
02/12/24 02:42 AM
Thanks to both of you, up, their website doesn't say squat about what it does. shock
Re: Draggy data recorders, what do they record? [Re: Cab_Burge] #3213011
02/12/24 01:18 PM
02/12/24 01:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Its NOT a data recorded past what has been stated from you last run. And they are quite accurate pretty cool little device.
Re: Draggy data recorders, what do they record? [Re: Al_Alguire] #3213018
02/12/24 01:28 PM
02/12/24 01:28 PM
NY
NY
Oh, and I think the only way to get the data is to pair it with your "Smart" phone. That can be a challenge for us older folk...
My buddy left his in the tow vehicle, paired it up before he left the pits. All was good. Got back from making a pass and had no run recorded on his phone. Took us a bit to figure out that it was in the WRONG Dodge! smile
Re: Draggy data recorders, what do they record? [Re: challenger451ci] #3213036
02/12/24 02:16 PM
02/12/24 02:16 PM
Oh, and I think the only way to get the data is to pair it with your "Smart" phone. That can be a challenge for us older folk...! smile
Smart Phone, VAS is dat shock
AKA aside I may have to step up to one of those, DANG IT shruggy
Re: Draggy data recorders, what do they record? [Re: Cab_Burge] #3213043
02/12/24 02:28 PM
02/12/24 02:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Here's a slip from my Mercedes. You can see the data displayed. The screen scot shows you what it will record. 0-30scrolled off the top of the page.
- Stu Harmon
