Manual Brake Adjustable Pushrod #3212792
02/11/24 03:37 PM
02/11/24 03:37 PM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
Changing my 70 RR from power disc to Manual Disc. I have the Mancini adjustable pushrod. What length is everyone starting with?
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Manual Brake Adjustable Pushrod [Re: A70Runner] #3212795
02/11/24 03:47 PM
02/11/24 03:47 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That depends on MS, Booster, etc. Start with it tight enough to not fall out and then adjust for pedal travel/feel
Re: Manual Brake Adjustable Pushrod [Re: Lefty] #3212806
02/11/24 04:37 PM
02/11/24 04:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
He's going from power to manual, no booster.
Can't help on the length question, while all my rides are manual brake, none of them are B bodies.
Re: Manual Brake Adjustable Pushrod [Re: Sniper] #3212821
02/11/24 05:20 PM
02/11/24 05:20 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Adjust the rod till the pedal is all the way up. Tighten the locknut. Done.
Re: Manual Brake Adjustable Pushrod [Re: Stanton] #3212840
02/11/24 06:21 PM
02/11/24 06:21 PM
CrazyD Offline
CrazyD  Offline
Check factory manual pushrod lengths on Brewer's website to get an initial length:
Brewer's Performance
Re: Manual Brake Adjustable Pushrod [Re: CrazyD] #3212906
02/11/24 11:02 PM
02/11/24 11:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up iagree And do be aware you need ~.030 clearance between the Push rod and M/C piston when the pedal is all the way up beer
Re: Manual Brake Adjustable Pushrod [Re: TJP] #3212936
02/12/24 12:56 AM
02/12/24 12:56 AM
iagree wrench scope up
Re: Manual Brake Adjustable Pushrod [Re: TJP] #3212980
02/12/24 10:39 AM
02/12/24 10:39 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
All the manual MC pushrods I've ever seen have that goofy little rubber/plastic retainer on the end of the pushrod that retains it in the MC. There is no adjustment possible.
Re: Manual Brake Adjustable Pushrod [Re: 6PakBee] #3213091
02/12/24 07:03 PM
02/12/24 07:03 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Quote
I'm gonna guess that you initially do the install and adjustment without the rubber retainer. Then remove the master, install the retainer and bolt up the master again. But I'm just guessin' !!
What I wanna know is what sort of feeler gauge you use to measure that clearance and where? Seems to me .030 at the rod end should equal X" of play at the pedal.
Re: Manual Brake Adjustable Pushrod [Re: A70Runner] #3213105
02/12/24 07:59 PM
02/12/24 07:59 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree have you mocked it up yet? I’m not 100% on the brand I got, but it was way too long, would have to cut off a good amount of the threaded part. I ended up using my stock 4 manual drum pushrod, the pedal is a little bit too high from ideal but it’s worked good for 12 years
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Manual Brake Adjustable Pushrod [Re: Stanton] #3213151
02/12/24 11:27 PM
02/12/24 11:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
the problem arises with the age of the cars, potential swapping of parts, our lovely one size fits all corporate America mindset and overseas manufacturing tolerances wink
on a power brake vehicle a tool such as this is used LINKY other ceaper versions are availabble.
On a manual brake car, removing the pushrod bolt from the pedal to make sure the pushrod is a tad shorter than the pedal when it just touches the stop will work best. one can also try unbolting the master from the firewall or check that the pedal is not buried against the stop beer
Re: Manual Brake Adjustable Pushrod [Re: metallicareload] #3213785
02/15/24 07:02 PM
02/15/24 07:02 PM
Mooresville, NC
Mooresville, NC
I’ll start at 6.75 (Found on another site) and go from there. I’ll let you all know how it went.
Thanks!
