Summit Aluminum Radiator- 440 Challenger
#32123
11/20/06 12:14 PM
11/20/06 12:14 PM
Posts: 390 Atlanta, GA/Blue Ridge GA
NotaHemi
super street
super street
Guys, I have been on hiatus for a very long time. took a break on the challenger for a while now am getting back to finishing it.
I need to know which universal radiator you guys are using from summit for these cars and how you mounted it.
I have done extensive searches but have come up with nothing.
I believe it was a circle track Ford application for less than $200. Not sure of the size etc.or how would be the best way to mount it.
I have a proform black magic electric fan and shroud to go on it.
Also there was somebody that had even posted part numbers for the necessary hoses that would mount right up (although I think that was a B-body although it should work on my E-body.
Any help would be greatly appreciated.
Thank you in advance.
Elmo
1974 Dodge Challenger 440 restoMod.
2006 Range Rover HSE
2004 Toyota Sequioa Ltd 4x4
Re: Summit Aluminum Radiator- 440 Challenger
[Re: NotaHemi]
#32124
11/21/06 11:10 AM
11/21/06 11:10 AM
NotaHemi
super street
super street
Wow. Guess noone here has a summit radiator. 48 hits and not one response ![](/ubbthreads/images/graemlins/confused.gif)
[Re: 79powerwagon]
#32128
11/21/06 12:32 PM
11/21/06 12:32 PM
NotaHemi
super street
super street
Thanks, Guys. Looks like summit has a replacement style for a $100 more for a charger. That should fit right up. Thanks again.
[Re: ZIPPY]
#32131
11/21/06 01:16 PM
11/21/06 01:16 PM
Posts: 27,728 places
79powerwagon
places
If you guys will list what hoses get the job done, I will archive it.
I'll look when I get home. The tags are still on there...
[Re: ZIPPY]
#32135
06/07/07 01:44 PM
06/07/07 01:44 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
For those who are on the road......
I did some digging and found Advance uses Dayco numbers, but they add a C at the beginning.
The lower hose is easy to remember: 1969 Hemi Roadrunner (or just about any other late 60s passenger car big block), Dayco 70592. It's just a stock big block lower hose, which is why that one won't often be in stock......
The upper hose will take a little more effort to remember.... Dayco 71654, which fits 1991-1994 Ford Ranger with a 3.0 V6.
Personally it's easier for me to remember the original application rather than a number. I don't like to carry build books in the car since the build is changing all the time, so this way works better for me.
If, for instance, a guy was stuck in the boonies with a split upper hose, he could just ask for one for a Ranger and get Goodyear, Kelly, or whatever brand is available rather than having to rely on the part number. Might come in handy someday.
FYI....
