trailer brakes #3212280
02/09/24 07:30 PM
02/09/24 07:30 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I've got an old flat bed car trailer that had the brakes fail some time back. We don't use it much so I put it off until now to get it fixed. One of the brake lines broke clean. I pulled the drums and found that the brakes were ok, but I'd like to replace the wheel cylinders along with all the lines and hose. I did replace the master a long time ago, but haven't found where I put it and it probably should get replaced as well. I found some off-brand brake assemblies for a reasonable price as well as Dexter (which they probably are) for about double. what would you guys do? Best source? I can get some pics of the assemblies later. nOh, and they are 10 x 2.25.
Re: trailer brakes [Re: Jim_Lusk] #3212284
02/09/24 07:41 PM
02/09/24 07:41 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Would complete assemblies, i.e. backing plates, wheel cylinders, shoes, hardware, already assembled, make more sense?
Then run new lines to a new master?
Re: trailer brakes [Re: moparmike1] #3212286
02/09/24 07:44 PM
02/09/24 07:44 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
That's what I'm leaning to, but the off-brand from E-trailer or the Dexter? I haven't found a master that looks like mine. Than again, mine is in a hiding place so I am just going on memory...
Re: trailer brakes [Re: Jim_Lusk] #3212288
02/09/24 07:47 PM
02/09/24 07:47 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I buy all my trailer parts at Johnson Supply but they are electric not hydraulic, I haven't used a hydraulic trailer brake set-up in decades, didn't know they were still available! https://johnsonssurplus.com/products/search?keyword=trailer%20brakes
JB Rhinehart, Realist
A-Body's RULE!
Re: trailer brakes [Re: Rhinodart] #3212292
02/09/24 07:59 PM
02/09/24 07:59 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Yeah, it looks like they don't have any hydraulic brake parts. I bought this trailer very used in 2001. I'm fixing it up before I give it to my older son as I now have the 20' enclosed. I don't really have the room for two car trailers. Otherwise I'd probably keep it.
Re: trailer brakes [Re: Jim_Lusk] #3212301
02/09/24 08:20 PM
02/09/24 08:20 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you have to replace pretty much everything on the brake system, I would sure look into going with the electric brakes. Even with adding the brake control (probably close to the cost of the master cylinder) on the truck, the electric brakes are likely going to be less expensive, and they have the added advantage of being able to apply only the trailer brakes to stop a tail wag condition, and they make it much easier to back the trailer up.
