AN Fittings/Hose - Quick Question #3210646
02/04/24 09:04 PM
02/04/24 09:04 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I've never used AN fittings before (don't care for the look). I'm doing some oiling mods to an AMC engine and need to use AN.
Question is: Can you interchange different brands of fittings and hoses as long as they are all the same size (e.g. -6)?
Re: AN Fittings/Hose - Quick Question [Re: VITC_GTX] #3210657
02/04/24 09:18 PM
02/04/24 09:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I prefer to use the same brand. Years ago I had a Russel-to-Earl's connection and they were slightly different enough male/female threads that I could tell.
That may have been an anomaly.
Surely others will reply.
Re: AN Fittings/Hose - Quick Question [Re: topside] #3210675
02/04/24 09:38 PM
02/04/24 09:38 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
You can, but I don’t.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: AN Fittings/Hose - Quick Question [Re: BloFish] #3210678
02/04/24 09:56 PM
02/04/24 09:56 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
If you want to keep it simple and cheap, and have quick, highly availible parts, go to a hydraulic shop and get jic fittings
Re: AN Fittings/Hose - Quick Question [Re: VITC_GTX] #3210692
02/04/24 10:26 PM
02/04/24 10:26 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks guys.
Van
Re: AN Fittings/Hose - Quick Question [Re: VITC_GTX] #3210729
02/05/24 02:10 AM
02/05/24 02:10 AM
Make sure and use the same brand for the hose and fittings, I use the Teflon line hoses for all oil and fuel lines, it will hold a lot more pressure and with stand a lot more heat than the other non-Teflon line type AN hoses will up scope wrench It is smaller in diameter and lighter also up Not as flexible though shruggy work
Re: AN Fittings/Hose - Quick Question [Re: VITC_GTX] #3210764
02/05/24 10:10 AM
02/05/24 10:10 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Answer: Yes. The dimensions of AN fittings are determined by specifications that all vendors adhere to.
Edit: This applies to the fitting end only. I cannot speak to the interchangeability of the hose end between brands.
Re: AN Fittings/Hose - Quick Question [Re: 6PakBee] #3210773
02/05/24 10:57 AM
02/05/24 10:57 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Try to keep all the brands the same for hoses and fittings. Some are interchangeable but not all. I believe it is Aeroquip that dimensionally others fittings will not fit on their hose. I prefer Fragola as they do have alot of custom adapter fittings, XRP is probably a tie for the top 2 for what I use.
Even though more towards the racing side of things with AN hose & fittings, I still wanted a OEM type of look.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: AN Fittings/Hose - Quick Question [Re: VITC_GTX] #3211756
02/07/24 10:27 PM
02/07/24 10:27 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
It depends on what you are mixing here. If you are trying to mix hose and hose ends from different mfg, then you may have issues as individual hose mfg may have different O.D. and that what the hose coupling/fitting is designed for. Think old school and Granimals clothes. Keep them matched and not mixed. Also, this "AN" hose you see listed is different in I.D. from industrial hose. The AN stuff is usually spec'd to be similar to tubing I.D. and not true I.D. as the size would indicate. Look up Fragola FRA-842006 on Summit's site and look at the I.D. It's less than 0.375" (0.344") and the O.D. is 0.560". Now compare that to Earl's Vapor Guard EAR-752066ERL and you'll see the I.D. is 0.375" and the O.D. is 0.625. These are critical dims in choosing the correct hose ends if you are going with resuables (screw together) hose ends.
Now when it comes to connectors/fittings, then the as long as the flare is 37deg you can mix and match parts, brands, material all day long between JIC and AN. Those are based on the thread size of the fitting.
And just an FYI...AN/JIC sizes are based on 1/16th's. 4=.25", 6=.375", 8=.50".....etc
Re: AN Fittings/Hose - Quick Question [Re: jb500] #3211816
02/08/24 02:56 AM
02/08/24 02:56 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Good to know. Thanks!
Re: AN Fittings/Hose - Quick Question [Re: VITC_GTX] #3211845
02/08/24 08:31 AM
02/08/24 08:31 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Go to the Aircraft Spruce web site for hose and AN fittings. They are the real stuff, not china made stuff like some suppliers sell. For installing the ends ATS sells the different size tools for that.
Re: AN Fittings/Hose - Quick Question [Re: 71birdJ68] #3211962
02/08/24 01:20 PM
02/08/24 01:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've also seen differences in the ID of fittings from different manufacturers.
And FWIW, braided stainless hose is pretty effective at marring paint if allowed to scrape/abrade against it.
