Anyone have a source for the tall #10 acorn palnuts.... #3211456
02/07/24 12:19 PM
02/07/24 12:19 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
.....as used on '69 side marker housings, '69 GTX quarter panel emblems and so on?
None of the usual suppliers seem to have them. There are some #8s out there but I need the larger #10.
Any known sources or leads?
Do not need to be exact original-appearing just have to function and it would be nice if they look fairly close.
I thought they were being reproduced but damned if I can find anything….
TIA
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3211503
02/07/24 02:01 PM
02/07/24 02:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd try Restoration Specialties and McMaster-Carr.
Not sure if Layson's or R/T Specialties (may have that name wrong) would have them.
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3211551
02/07/24 03:33 PM
02/07/24 03:33 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
Not sure it's the correct size, but found these on ebay.
https://www.ebay.com/itm/2335493982...cXRE6ob1HmA%3D%3D%7Ctkp%3ABk9SR_au6tCwYw
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: SNK-EYZ] #3211576
02/07/24 04:25 PM
02/07/24 04:25 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
For reference this one is from my Cuda's rear marker reflector housing. I believe they're the same and it takes a 7/16 wrench. To the best of my knowledge these are NOT available.
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: EW1BH27] #3211593
02/07/24 05:26 PM
02/07/24 05:26 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Call these guys, https://rainbowboltsupply.com/catalog If they are available they will know. They are not listed in their catalog though.
My Monster are real!
Living within your means makes life pretty easy.
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3211597
02/07/24 05:34 PM
02/07/24 05:34 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: 67vertman] #3211603
02/07/24 05:44 PM
02/07/24 05:44 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Amk USED to make them . But discontinued them several years ago, No idea why.
But you best bet is going to be either RT Specialties or Restoration Specialties .
If they dont have them, No ones does
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: gtx6970] #3212116
02/08/24 11:40 PM
02/08/24 11:40 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Megapartsusa.com has them. Set of 8 for $20 USD. I just bought a set and they appear to be a spot-on match. Paul p/n MP-SMN139
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: iapco103] #3212119
02/09/24 12:07 AM
02/09/24 12:07 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Wrong ones.
Those are for a machine thread style
They are incorrect for the ops intended use
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: gtx6970] #3212260
02/09/24 06:04 PM
02/09/24 06:04 PM
Maryland
MoparMike1974 Offline
Maryland
Try here, they have a lot of automotive fasteners.
https://www.clipsandfasteners.com/
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3212293
02/09/24 08:02 PM
02/09/24 08:02 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
TIA
Here U go..
Classic carries, made by AMK...
Just my $0.02.... wink
https://www.classicindustries.com/product/6027352.html
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: Sinitro] #3212695
02/11/24 09:04 AM
02/11/24 09:04 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
They came up very early in the search. They will probably snap the studs off if forced on.
Wrong size. Those are #8. I need #10.
T boomer is sending me a bag of used ones of various sizes, I'll check/maybe sacrifice one and see if I can modify the #8 versions to work,
but I'd really rather not mess around just get the right stuff to begin with.
If I can come up with a handful of good ones then I'll use those in the visible areas and switch to flat palnuts with a dab of 3m strip caulk for everything else.
It'll be functional, at least, which is the important thing.
I don't understand why this is no longer made, the car is only 55 years old wink {/sarcasm]
Rich H.
Esse Quam Videri
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: 67vertman] #3212725
02/11/24 11:16 AM
02/11/24 11:16 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3212726
02/11/24 11:18 AM
02/11/24 11:18 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
tom at r/t specialties is unresponsive so far.
I'm not expecting to find anything at this point.
Hard "no" from Dante who suggested tom.
Rich H.
Esse Quam Videri
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3212772
02/11/24 01:55 PM
02/11/24 01:55 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if it will help you. i have 3 of them new.
yours if you want them
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: gtx6970] #3223367
03/28/24 02:19 PM
03/28/24 02:19 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
These ?
I found enough to do 2 cars
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: gtx6970] #3223564
03/29/24 03:57 PM
03/29/24 03:57 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
If they're #10, yeah, those are the Unicorn Teeth.
Rich H.
Esse Quam Videri
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3223592
03/29/24 09:40 PM
03/29/24 09:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
have you tried removing the #8 generic looking nut and seeing if a #10 will fit in the outside cap. there are likely a multitude of sources for the nuts
Looking at the following website shows nuts for a 5/32 stud and 3/16 stud both having a 3/8 hex.
if I'm thinking correctly a #10 usually measures about .187 or 3/16. #8 is 5/32 or about .164
So if one is able to swap the nut inside the housing 😁
LINKY
the above is just one site, I'm sure there are others
Might just get lucky wink keep us posted beer
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: TJP] #3224369
04/01/24 08:20 PM
04/01/24 08:20 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I have a #10 that fell out because the acorn more or less rotted off.
Here’s a picture of it next to a #8 that has the right external dimension but
The wrong nut inside it. The shell is 7/16 hex, the nut inside is 3/8 hex so
Some of what’s holding it together is Forming on the edge of the “washer”.
Maybe I’m not feeling creative enough at the moment but not sure how I’d duplicate that
Without investing in tooling.
Rich H.
Esse Quam Videri
Re: Anyone have a source for the tall #10 acorn palnuts.... [Re: ZIPPY] #3224374
04/01/24 08:23 PM
04/01/24 08:23 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I’ve come across 2 types of #8 as well, the smaller type and the larger which is the tricky one….because it’s
the same on the exterior as the #10.
Rich H.
Esse Quam Videri
