Search for #10 tall acorn palnuts….. #3211437
02/07/24 11:34 AM
02/07/24 11:34 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
…..as used on 69 b body side markers, and a lot of other places.
None of the usual suppliers seem to have them. There are some #8s out there but I need the larger #10.
Any known sources or leads?
Do not need to be exact original, just have to function and look fairly close.
I thought they were being reproduced but damned if I can find anything….
Rich H.
Esse Quam Videri
Re: Search for #10 tall acorn palnuts….. [Re: ZIPPY] #3211485
02/07/24 01:40 PM
02/07/24 01:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From Grainger
Re: Search for #10 tall acorn palnuts….. [Re: John_Kunkel] #3211510
02/07/24 02:11 PM
02/07/24 02:11 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks, I will have to sacrifice one and see if I can cut threads with a die.
Most of the studs are marked up pretty deeply with the very diagonal threads the self cutting nut makes, but
maybe I can go over them with a die and they will be good enough to hold.
Rich H.
Esse Quam Videri
Re: Search for #10 tall acorn palnuts….. [Re: ZIPPY] #3211552
02/07/24 03:34 PM
02/07/24 03:34 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Not sure if it's the correct size, but found these on ebay. https://www.ebay.com/itm/2335493982...cXRE6ob1HmA%3D%3D%7Ctkp%3ABk9SR_au6tCwYw
Re: Search for #10 tall acorn palnuts….. [Re: SNK-EYZ] #3211671
02/07/24 08:59 PM
02/07/24 08:59 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I will have to look, but I think I have a bunch of those. Some NOS ones too. If I don't get back to you by Friday night, shoot me a reminder!
Re: Search for #10 tall acorn palnuts….. [Re: 70HemiGTX] #3211825
02/08/24 04:41 AM
02/08/24 04:41 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
AMK sells these 1/8" for $1 each. Cheap enough to ruin a few re-threading for #10. Look here.
You definitely want the mastic or similar or add your own. DAMHIK.
Re: Search for #10 tall acorn palnuts….. [Re: kentj340] #3211973
02/08/24 01:56 PM
02/08/24 01:56 PM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Ask questions when ordering, the small ones are readily available.
EDIT: Corrected the wrench size for the large one
Re: Search for #10 tall acorn palnuts….. [Re: ZIPPY] #3212156
02/09/24 10:19 AM
02/09/24 10:19 AM
tboomer Online content
tboomer  Online Content
Zippy man! Check your pms! up
Re: Search for #10 tall acorn palnuts….. [Re: tboomer] #3212299
02/09/24 08:18 PM
02/09/24 08:18 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
If you can find the 3/8 one with the small hole you can purchase the #10 stamped nut .56 D Mech ZDC P/N B-12980 from AMK and make your own.
You'll need to take the small hole 3/8 and remove the stamped nut and replace it with the #10 nut. Not 100% correct but you won't see it in the end
Contact me if you need help with the process
NS1AAR
Re: Search for #10 tall acorn palnuts….. [Re: ns1aar] #3212302
02/09/24 08:31 PM
02/09/24 08:31 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Search for #10 tall acorn palnuts….. [Re: BloFish] #3212381
02/10/24 07:09 AM
02/10/24 07:09 AM
Watch your mail Rich! I sent ya a couple! On my dime! wave
Re: Search for #10 tall acorn palnuts….. [Re: ZIPPY] #3212391
02/10/24 09:02 AM
02/10/24 09:02 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Are those shown in the picture the originals or examples?
If originals why not refinish them?
Re: Search for #10 tall acorn palnuts….. [Re: AAR#2] #3212424
02/10/24 11:18 AM
02/10/24 11:18 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Hey ZIPPY if you buy any of them from the links that have been posted can you please tell me if they're actually the correct larger one that you're looking for. I've got friends endlessly looking for the bigger ones with no luck. They've bought from "pictures" only to find they were the smaller type. Thanks.
Re: Search for #10 tall acorn palnuts….. [Re: BloFish] #3212720
02/11/24 11:06 AM
02/11/24 11:06 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Originally Posted by BloFish
Wrong size. Those are a #8. I need #10.
The smaller size would most likely snap the studs off if forced on.
Tboomer is sending an assortment of used uses of various sizes, I'll likely sacrifice a smaller one to see if I can open it up to #10.
Rich H.
Esse Quam Videri
Re: Search for #10 tall acorn palnuts….. [Re: AAR#2] #3212721
02/11/24 11:07 AM
02/11/24 11:07 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Because they don't hold very well anymore, and because I need alot more of them than I have.
Rich H.
Esse Quam Videri
Re: Search for #10 tall acorn palnuts….. [Re: ns1aar] #3212723
02/11/24 11:09 AM
02/11/24 11:09 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I'd thought about that, but seems like more effort than I wanted to put into it.
Grind off the old nut and tack weld the larger size on?
Rich H.
Esse Quam Videri
Re: Search for #10 tall acorn palnuts….. [Re: EW1BH27] #3212724
02/11/24 11:10 AM
02/11/24 11:10 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I think the larger #10 ones are probably gone for good at this point....But sure if I find any I'll get the word out.
Rich H.
Esse Quam Videri
