SB flywheel interchangability question #3210832
02/05/24 02:11 PM
02/05/24 02:11 PM
alberta
Publicbottle Offline OP
alberta
I have a 69 340 Ive been running in my challenger for 7-8 years I will soon be swapping for a magnum 360 stroked 408 soon to be out of the local engine builders shop. I am trying to get my pre-planning sorted out here...hence a question for the group...
Can I use the same flywheel from my 340 on the magnum block 360? (internally balanced) If so, I would then assume the bellhousing will also work?
Thanks for your help
Re: SB flywheel interchangability question [Re: Publicbottle] #3210864
02/05/24 04:33 PM
02/05/24 04:33 PM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Given that your Magnum has been converted to internal balance, you should be able to use your LA flywheel. Amusing it is, in fact neutral balance itself.
Bellhousing should be fine as well.
Re: SB flywheel interchangability question [Re: usp4u] #3211121
02/06/24 02:24 PM
02/06/24 02:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree But you should dial the bell to the different block.
Re: SB flywheel interchangability question [Re: John_Kunkel] #3211377
02/07/24 07:49 AM
02/07/24 07:49 AM
Originally Posted by John_Kunkel
[quote=usp4u]
iagree wrench scope up
Re: SB flywheel interchangability question [Re: John_Kunkel] #3211428
02/07/24 11:12 AM
02/07/24 11:12 AM
alberta
alberta
Yes I plan to dial the bellhousing, thanks for the help!!
