Re: SB flywheel interchangability question
[Re: usp4u]
#3211121
02/06/24 02:24 PM
02/06/24 02:24 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Given that your Magnum has been converted to internal balance, you should be able to use your LA flywheel. Amusing it is, in fact neutral balance itself.
Bellhousing should be fine as well. But you should dial the bell to the different block.
