Re: Need Opinion on Cam bearing #4 Oil Hole [Re: 19_Dart_68] #3211104
02/06/24 01:33 PM
02/06/24 01:33 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Send it....
Re: Need Opinion on Cam bearing #4 Oil Hole [Re: Al_Alguire] #3211119
02/06/24 02:13 PM
02/06/24 02:13 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Old Racers used to put the bearings in off center (far worse than that) to preserve more oil for the mains, like of an easy way so slightly restrict the flow for higher priority oiling.
WIZE
In Car:
Re: Need Opinion on Cam bearing #4 Oil Hole [Re: JohnRR] #3211431
02/07/24 11:21 AM
02/07/24 11:21 AM
Originally Posted by JohnRR
now I just drill a smaller hole in a different spot and put the smaller hole over the passage.
excellent idea John! I'm gonna do that on my next one, all I gotta do now is lookup/decide what dia to drill em to. RR
Re: Need Opinion on Cam bearing #4 Oil Hole [Re: 19_Dart_68] #3211482
02/07/24 01:35 PM
02/07/24 01:35 PM
an8sec70cuda Offline
Nothing wrong w/ that at all. Run it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need Opinion on Cam bearing #4 Oil Hole [Re: 19_Dart_68] #3211490
02/07/24 01:45 PM
02/07/24 01:45 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
The oil passages to the cam bearings are too large to begin with, that will still supply more oil than is needed.
I restrict these to .090" or .060" depending on the project
Re: Need Opinion on Cam bearing #4 Oil Hole [Re: LSP] #3211635
02/07/24 07:03 PM
02/07/24 07:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you're losing sleep over it, run a drill bit through it. That said, I challenge any engine builder to pound in all 5 bearings and have them all line up with the oil holes perfectly !!
Re: Need Opinion on Cam bearing #4 Oil Hole [Re: Stanton] #3212060
02/08/24 06:50 PM
02/08/24 06:50 PM
Pennsylvania
19_Dart_68 Offline OP
Pennsylvania
Nah, I'm gonna send it.
68 Dart - 440 Swap in Progress...please stand by
