3500 4wd GearVendors OD unit; $400 OBO #3210362
02/03/24 09:43 PM
02/03/24 09:43 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Just to be clear; this is not mine.
'Worked when pulled. It came on my truck. And i didnt like it. It is for a dodge 3500 with a 5 speed nv4500. It is for a np241 transfercase. I have all the parts that make it work. The switch and relay box. And the wiring. My truck is a 1998. So im sure it works on 98-02 trucks. $400 obo
www.facebook.com/marketplace/item/869292778279461
Master, again and still
Re: 3500 4wd GearVendors OD unit; $400 OBO [Re: DaveRS23] #3210408
02/04/24 07:48 AM
02/04/24 07:48 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Interesting piece. But how much OD do you need on a factory truck? Or are yoiu splitting gears? drive
Re: 3500 4wd GearVendors OD unit; $400 OBO [Re: redraptor] #3210416
02/04/24 08:51 AM
02/04/24 08:51 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
On a level highway
with little head or side wind
an unloaded pickup truck drivetrain
needs more OD
to get anywhere close to max fuel economy or minimum engine wear.
I am tempted to say
“up to 2% grade hills”
instead of “level.”
Re: 3500 4wd GearVendors OD unit; $400 OBO [Re: 360view] #3210431
02/04/24 11:10 AM
02/04/24 11:10 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The countershaft bearing is already failure prone in NV4500 trans. You add another overdrive and spin it faster is just asking for trouble.
Re: 3500 4wd GearVendors OD unit; $400 OBO [Re: fbs63] #3210856
02/05/24 04:11 PM
02/05/24 04:11 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
That's not how an add on overdrive works.
