3500 4wd GearVendors OD unit; $400 OBO
#3210362
02/03/24 09:43 PM
02/03/24 09:43 PM
Posts: 12,250 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just to be clear; this is not mine. ' Worked when pulled. It came on my truck. And i didnt like it. It is for a dodge 3500 with a 5 speed nv4500. It is for a np241 transfercase. I have all the parts that make it work. The switch and relay box. And the wiring. My truck is a 1998. So im sure it works on 98-02 trucks. $400 obo www.facebook.com/marketplace/item/869292778279461
Master, again and still
Re: 3500 4wd GearVendors OD unit; $400 OBO
[Re: fbs63]
#3210856
02/05/24 04:11 PM
02/05/24 04:11 PM
Posts: 1,722 Chicagoland
Cooter
Chicagoland
The countershaft bearing is already failure prone in NV4500 trans. You add another overdrive and spin it faster is just asking for trouble. That's not how an add on overdrive works.
