Page 4 of 5 1 2 3 4 5
Re: 7.75x14" blue streak repro tires choices? [Re: autoxcuda] #3203417
01/09/24 01:29 PM
01/09/24 01:29 PM
So Cal
autoxcuda Offline OP
So Cal
Completed first pass down bottom of driver's side rocker. May clean undercoating overspray again.
Re: 7.75x14" blue streak repro tires choices? [Re: autoxcuda] #3203418
01/09/24 01:34 PM
01/09/24 01:34 PM
So Cal
So Cal
Drivers side markings on front eyelet of leaf spring
Looks like medium or pastel green on inside and white on outer side.
Anyone else find this on 66 Hemi Auto's?
Isn't there a list of leaf spring markings out there?
Re: 7.75x14" blue streak repro tires choices? [Re: autoxcuda] #3203725
01/10/24 11:02 PM
01/10/24 11:02 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Any idea if there is a Gasket under the hood ornament?
Is there just the one data tag under hood? No hemi fender tag correct ?
Re: 7.75x14" blue streak repro tires choices? [Re: gtx6970] #3203728
01/10/24 11:13 PM
01/10/24 11:13 PM
So Cal
So Cal
No gasket
Only one tag
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3203974
01/12/24 02:31 AM
01/12/24 02:31 AM
So Cal
So Cal
Pulled the gas sender to check the tank and fuel condition.
Looks real good. Sucked the old gas out. Then blew out the body line.
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3207124
01/22/24 10:53 AM
01/22/24 10:53 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
If you have an opportunity please take some pictures of the original wheels. The stamping around the valve stem , area around the lug bolt holes, and stamping/ manufacturer inside the hoop if you pull the tires.
Thank you, Matt
Re: Now: 66 Hemi Satellite survivor [Re: mattsmopars] #3207209
01/22/24 02:53 PM
01/22/24 02:53 PM
So Cal
So Cal
Thank you, Matt
Will do.
What does everyone this of these numbers on the tail pipe tips?
K-2781286
Factory or aftermarket?
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3207534
01/23/24 02:15 PM
01/23/24 02:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
IMO,
OEM. But as to if factory installed or over the counter???
. Ive no idea. My car has replacement exhaust
Re: Now: 66 Hemi Satellite survivor [Re: gtx6970] #3208140
01/25/24 05:57 PM
01/25/24 05:57 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Just a beautiful Satellite! I had a large size poster of a collage of Hemi Mopar's
when I was in high school back in the late 70's- early 80's. This (Pete Haldiman) Satellite was one of the cars
in that poster! Along with Marvin Hughes' '64 Hemi Dodge, and a handful of other Hemi cars.
I also am sure I had a copy of that Car Craft magazine too, with the SuperCar Shootout.
Wish I still had them. Good luck with that Plymouth! up
Plymouth Makes It!
Re: Now: 66 Hemi Satellite survivor [Re: RoadRunnerLuva] #3208206
01/26/24 01:13 AM
01/26/24 01:13 AM
So Cal
So Cal
Actually that's a gold Hemi Bel II is a convertible (I believe Hughes’)
Pete’s car was the 69 Hemi 500 with dealer vinyl top. Sold to C500's dad. And Radke's Hemi Daytona replaced it (now Lembeck's in F6)
The poster was from Automobile Quarterly. AQ used pictures of Pete’s 500 for an article on Wing Cars.
I bought this poster never used about 5 or so years ago at a Spring Fling. From my garage wall right now:
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3208322
01/26/24 04:18 PM
01/26/24 04:18 PM
Planet Earth
Planet Earth
Yup, that's the poster! My memory is fuzzy, sorry, I just remembered a gold Plymouth
in that poster, didn't remember it being a convertible...it been over forty years, since I last
saw it. wink Regardless, you have a gorgeous car, I hope you get many years of happiness with it. up
Plymouth Makes It!
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3208376
01/26/24 08:42 PM
01/26/24 08:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Car on upper right hand corner is ?????
The Belv conv was Marvin Hughes at the time ,, same for the 64 car
Same 66 Belv vert today
Re: Now: 66 Hemi Satellite survivor [Re: gtx6970] #3208405
01/27/24 12:38 AM
01/27/24 12:38 AM
So Cal
So Cal
Says Carl Dwiggins on the silver/red 66 Hemi Satellite. Same owner for the dark blue/black 68 Hemi RR under it.
Re: 7.75x14" blue streak repro tires choices? [Re: autoxcuda] #3208556
01/27/24 04:48 PM
01/27/24 04:48 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I can offer this pic of a set of original seals from a 68 4 door v-8 coronet.
I cannot recall if there was anything passing through the slotted hole on the smaller piece.
Re: 7.75x14" blue streak repro tires choices? [Re: srt] #3219540
03/10/24 02:43 PM
03/10/24 02:43 PM
So Cal
So Cal
Carbs done last night from me just rebuilding and cleaning the grime of them…
Re: 7.75x14" blue streak repro tires choices? [Re: autoxcuda] #3219583
03/10/24 05:29 PM
03/10/24 05:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Nice, what did you clean them in / with
Re: 7.75x14" blue streak repro tires choices? [Re: gtx6970] #3219588
03/10/24 05:52 PM
03/10/24 05:52 PM
So Cal
So Cal
Just brake clean and brass wire brushes. Lightly go over with steel wire brushes as last resort. And repetition.
Wenol polish on the brass. And some wenol on stains in corners with a Q-tip and/or stiff plastic brush.
I did notice the special carb nuts. They have a slightly raised then machined flat surface to the ends.
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3219735
03/11/24 01:16 PM
03/11/24 01:16 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Now I know what my silver car will look like finished (black interior)
Oops, that pic is a Satellite mines a Bel
Re: Now: 66 Hemi Satellite survivor [Re: cudaman1969] #3221061
03/17/24 03:12 PM
03/17/24 03:12 PM
So Cal
So Cal
Changed the trans pan gasket and filter.
Went with the new type Mopar plastic ribbed silicone gasket.
BEFORE
BEFORE
AFTER
AFTER
Re: Now: 66 Hemi Satellite survivor [Re: autoxcuda] #3221088
03/17/24 04:31 PM
03/17/24 04:31 PM
tboomer Offline
tboomer  Offline
That looks good! Did you re-use the factory bolts? up
