Air cleaner and seal to hood - non A12 car but 6 barrel hood #3207299
01/22/24 07:40 PM
01/22/24 07:40 PM
GA
roadrunninMark Offline OP
GA
I have a non A-12 69 road runner that has a fiberglass 6 barrel hood (I haven't cut the bottom of the hood yet). I am looking for an air cleaner with piece that seals it (press fit I assume) to the bottom of the hood. I have a single 4 barrel style F.I. unit (FItech) that it will bolt to with a single center stud. Can someone point me in the right direction on where I can get an aircleaner w/ seal to hood gasket setup? Pic below but need for single 4 barrel. Doesn't have to be an exact copy, just something that works and looks good.
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: roadrunninMark] #3207321
01/22/24 08:59 PM
01/22/24 08:59 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: GomangoCuda] #3207323
01/22/24 09:06 PM
01/22/24 09:06 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
WOW shock I have to agree up
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: A12] #3207392
01/23/24 01:36 AM
01/23/24 01:36 AM
GA
GA
Wow, that is expensive! I did a little searching and found this article. I am leaning to make this work..... https://moparconnectionmagazine.com...ld-your-own-air-grabber-with-kn-filters/
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: roadrunninMark] #3207462
01/23/24 11:34 AM
01/23/24 11:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's cheaper than the A12 repop , I was going to suggest to just get the A12 one and modify it but that's a lot of money to start with.
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: JohnRR] #3207532
01/23/24 02:12 PM
01/23/24 02:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
There is / or was a member here making glass repops . But dont remember the scree name or if he is still doing it.
He made me a TA style air cleaner for the dual 4 hemi to fit an AAR hood.
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: gtx6970] #3207616
01/23/24 07:16 PM
01/23/24 07:16 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
That article reminds me that some 60s and 70's Fords had giant air cleaner housings.
Maybe find one to cut up?
Angry white pureblood male
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: gtx6970] #3207617
01/23/24 07:18 PM
01/23/24 07:18 PM
GomangoCuda Offline
GomangoCuda  Offline
His screen name was PAINT IT BLACK. He quit that business some years ago but who knows maybe he's bored and will do one for you.
Re: Air cleaner and seal to hood - non A12 car but 6 barrel hood [Re: GomangoCuda] #3207624
01/23/24 07:50 PM
01/23/24 07:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Maybe I'm missing something here, but why not just fabricate a base plate and seal it to the hood ?
For a seal, either foam or a flanged rubber strip can work.
At the carb, either hole-saw or punch the base plate 5" & file-finish to 5 1/8", or attach an air cleaner base.
A filter element can be retained by a number of methods.
