Clutch Linkage Fork Release Rod #3467235 [Re: Memongo] #3206718
01/21/24 01:06 AM
01/21/24 01:06 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Clutch Linkage Fork Release Rod #3467235. Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
A B C E Body Speedometer Gears [Re: Memongo] #3206719
01/21/24 01:07 AM
01/21/24 01:07 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
A B C E Body Speedometer Gear 27 Teeth White. Fit 833, 904 and 727 Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
A B C E Body Speedometer Gear 34 Teeth Green. Fit 833, 904 and 727 Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1962-78 Automatic Transmission Torque Converter Drain Cover [Re: Memongo] #3206720
01/21/24 01:08 AM
01/21/24 01:08 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
1962-78 Automatic Transmission Torque Converter Drain Cover. Used, $10 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
46RE Slip Yoke [Re: moparts] #3206853
01/21/24 01:59 PM
01/21/24 01:59 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
46RE Slip Yoke - I picked this up for a A518 swap, but turns out my non-lockup A518 takes a regular 727 yoke. This was used with a 46RE. Not sure if it'll fit later lock-up 46RH's. Uses a 7290 u-joint. $40 shipped from West Sacramento, CA (PP F&F, postal money order, or check). Or $20 local pick up.
If desired, I can include the 7290 weld yoke for a 3" driveshaft, but you'll have to cut off the weld and small section of old driveshaft. I can also toss in the old u-joint and c-clips (still nice and tight, but can use a a good scrub).
yoke 2.JPG (1151 downloads)
69 b-body Dana 60 [Re: moparts] #3207232
01/22/24 03:55 PM
01/22/24 03:55 PM
Appleton
3
39Dodge Offline
39Dodge  Offline
Appleton
1969 B-body Dana 60. 35 spline axles with long studs, powr-lok differential with 3.54 gears, 7290 yoke with Moroso caps and through bolts. has chrome cover. complete with 11x2 heavy duty brakes including drums and parking brake cables. i do not have pictures as it is still in car. spring perches are moved to fit 71 b-body $3000.00
NOS A BODY CONSOLE BOOT 4-SPEED [Re: 39Dodge] #3207277
01/22/24 05:51 PM
01/22/24 05:51 PM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
Part number 2660422 never mounted new
$140 shipped lower 48
A bit dusty. Been on my shelf probably 20 years if not more.
Re: NOS B BODY CONSOLE BOOT 4-SPEED [Re: SMILINJOE] #3207279
01/22/24 05:55 PM
01/22/24 05:55 PM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
I have two NOS new never mounted 4-speed console boots
Part # 2996454
$150 each shipped lower 48
A bit dusty been on my shelf for at least 20 plus years.
Small block Lakewood bell housing [Re: SMILINJOE] #3209978
02/02/24 12:12 PM
02/02/24 12:12 PM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
Small block Mopar Lakewood bell housing with block plate. $450.00 plus shipping. Payment by postal money order. Please PM me if interested. Thank you,
70 18 spline transmission case [Re: IROC78] #3210369
02/03/24 10:43 PM
02/03/24 10:43 PM
Mass
charge70 Offline
charge70  Offline
Mass
I'm rebuilding a 70 18 spline gear box out of a 69 Road Runner.Obviously not the original for the car. The VIN on the side pad is A0179693.Anybody out there own or know where this car is?The case is in excellent shape.Will only trade for another case,nothing else is included and only to the owner of the car it belongs in. Time is a factor,so this would need to be done quickly.PM me here. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 70 18 spline transmission case [Re: charge70] #3211433
02/07/24 11:24 AM
02/07/24 11:24 AM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
I have a couple rebuilt 4-speed transmission for sale.
18 spline 1970 dual shifter mount $2100
23 spline aluminum main case from A body overdrive. Still has overdrive gears with a b body tail shaft. $1400
A body 23 spline 1968 VIN stamping on pad. $1400
Have Z bars bearing forks and lots of misc small parts. Not enough time to separate and list right now.
PM with questions
Re: Quick Time Small Block Bell Housing [Re: SMILINJOE] #3211434
02/07/24 11:30 AM
02/07/24 11:30 AM
Valpo Indiana
SMILINJOE Offline
SMILINJOE  Offline
Valpo Indiana
Quick Time 6072 H-12 with engine plate
Have all the extra parts when new including bearing retainer ring.
$590 shipped lower 48
Re:early a body 4 speed [Re: SMILINJOE] #3212787
02/11/24 03:14 PM
02/11/24 03:14 PM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
have a early a body 4 speed (no vin pad)slip yoke version,moves freely pretty clean inside can text pics if interested must pu in sw michigan $400.00 oboSOLD
Re: 70 18 spline transmission case [Re: charge70] #3213280
02/13/24 06:50 PM
02/13/24 06:50 PM
Mass
charge70 Offline
charge70  Offline
Mass
Parts arriving for the rebuild next 2 days,once I start this case will be unavailable.
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3214722
02/19/24 07:19 PM
02/19/24 07:19 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
SMR transmissions B/RB to small block transmission adapter kit. Part number SM99-100P for a 6 bolt crank. New in box, the box has been opened but only for inspection, never installed the kit. for info: https://smrtrans.tripod.com/smrtransmissionsintro/id9.html $500 + shipping PM here or phone (716) 655-0625 ask for Gary or leave a message ( this is a land line)
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3214724
02/19/24 07:22 PM
02/19/24 07:22 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
SOLD JW Ultra Bell 92457 Big Block Chrysler to TF727 or A518 Brand new in box $500 + shipping PM here or phone (716) 655-0625 ask for Gary (this is a land line)
4 sp parts [Re: RalleyA12] #3214971
02/20/24 05:20 PM
02/20/24 05:20 PM
Canada
W
westfort Offline
westfort  Offline
W
Canada
Parts for sale 4 sp parts have short tailshaft as well
$1234 email a.oger@hotmail.com
New Cope Manual Reverse Valve body Turbo Action Shifter [Re: moparts] #3215008
02/20/24 08:29 PM
02/20/24 08:29 PM
blewbyu Online content
blewbyu  Online Content
All items brand new never installed and it is the low band apply $1100.00 new. Will sell for $900.00 plus shipping. May seperate but prefer to sell as a package. blewbyu2bad@aol.com
IMG_6349 (2).jpg (669 downloads)
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3217819
03/03/24 07:39 PM
03/03/24 07:39 PM
Pa
Hemihead2 Offline
Hemihead2  Offline
Pa
Mopar Big block 10.5” Aluminum bell-housing #2892513 OEM 383/426/440 1970-72 B/E body cars. In as used condition with all threads chased (although bottom bolt threads are not perfect) with no cracks noted. Includes clutch fork pivot bracket. Asking $550 picked up or + shipping from Pa.
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3218653
03/06/24 05:26 PM
03/06/24 05:26 PM
chicago,il
W
walleyebum Offline
walleyebum  Offline
W
chicago,il
for sale NEW TCI StreetFighter Converter,142200 Chrysler, 1967-81 Torqueflite 727, 24-Spline,525.00 plus shipping
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3220974
03/17/24 09:45 AM
03/17/24 09:45 AM
Locomotion Offline
Locomotion  Offline
727/904 flexplate P4529751 AB 10" x 7/16" bolt performance converter bolt pattern - 6 bolt crank. NOS, expired SFI sticker.
$65.00 including shipping within the 48 states,
*****SOLD*****
Shipped from Florida 32117
Sorry, no PayPal.
locomo@bellsouth.net
