Re: Oliver rods
[Re: T-bar]
#3206728
01/21/24 04:19 AM
01/21/24 04:19 AM
Posts: 4,457 Washington
madscientist
Washington
I spun a big end bearing on 1 of my Oliver rods so who would be the best to buy a new one from please? How bad did it get hurt? That’s a pretty tough rod. I’ve turned them blue, replaced the bolts, resized them and put them right back in.
Re: Oliver rods
[Re: madscientist]
#3206941
01/21/24 05:51 PM
01/21/24 05:51 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
I spun a big end bearing on 1 of my Oliver rods so who would be the best to buy a new one from please? How bad did it get hurt? That’s a pretty tough rod. I’ve turned them blue, replaced the bolts, resized them and put them right back in. Without Magina fluxing them for cracks first?
Re: Oliver rods
[Re: Cab_Burge]
#3206971
01/21/24 07:41 PM
01/21/24 07:41 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Oliver will make and sell just one replacement rod if necessary. You would need to give them the order number off of the rod and big end and small end weights, if any different from what they originally manufactured.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: Oliver rods
[Re: Cab_Burge]
#3207016
01/21/24 09:50 PM
01/21/24 09:50 PM
madscientist
Washington
I spun a big end bearing on 1 of my Oliver rods so who would be the best to buy a new one from please? How bad did it get hurt? That’s a pretty tough rod. I’ve turned them blue, replaced the bolts, resized them and put them right back in. Without Magina fluxing them for cracks first? Nope. No need to. I turned them blue, I didn’t kill them. If I thought it needed it I would have.
Re: Oliver rods
[Re: AndyF]
#3207099
01/22/24 09:49 AM
01/22/24 09:49 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Send it to Oliver and have them check it out. They'll either tell you it is okay or they'll make a replacement. You would need a hardness checker to tell if it has lost strength. Engine shops typically don't have hardness checkers, you would have to go to an engineering test lab for that. The big end is usually distorted when the rod turns blue and the bolts usually need to be replaced. The rod may or may not be fine, all depends how hot it got. Oliver is great to deal with. Send it back to them and let them advise you on the best route to take.
