'62 B-Body K Member - All V8 The Same? #3205456
01/17/24 01:49 AM
01/17/24 01:49 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
'62 B body with the flat pedestal motor mounts. Are they like the '63 and up where there are two different K members for the small block and big block or will the '62 K member accommodate both?
Re: '62 B-Body K Member - All V8 The Same? [Re: VITC_GTX] #3205465
01/17/24 02:47 AM
01/17/24 02:47 AM
I like to swap those early K members to the later 1966 to 1971 B body V8 K members, preferably to the 1968 to 1971 with the better idler arms. up scope wrench up
That moves the motors back around 1.5 to 2.0 inches and down a little which helps make the weight distribution better as well as carb air cleaner to hood clearances a little better as well as header choices better up work wrench twocents
Re: '62 B-Body K Member - All V8 The Same? [Re: Cab_Burge] #3205466
01/17/24 02:51 AM
01/17/24 02:51 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I was hoping you would see this post Cab.
The newer K member may be in the future.
Short term, can I put a big block in a '62 that came with a small block or are the K members different?
Re: '62 B-Body K Member - All V8 The Same? [Re: VITC_GTX] #3205479
01/17/24 06:07 AM
01/17/24 06:07 AM
A727Tflite Offline
A727Tflite  Offline
All V-8’s except Hemi will fit on the same k-frame. There was an early for 62 k-frame that used a can mount - not sure if that applies to them.
Re: '62 B-Body K Member - All V8 The Same? [Re: VITC_GTX] #3205560
01/17/24 12:35 PM
01/17/24 12:35 PM
AndyF Online content
AndyF  Online Content
Bottom picture shows a 1965 V8 K frame if this helps. Top picture is a 1970-71 B body K frame which moves the engine back an inch or so. Both of these K frame are for sale in the classifieds if you're interested in either one.
Re: '62 B-Body K Member - All V8 The Same? [Re: A727Tflite] #3205566
01/17/24 12:43 PM
01/17/24 12:43 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks!
Re: '62 B-Body K Member - All V8 The Same? [Re: VITC_GTX] #3205601
01/17/24 01:52 PM
01/17/24 01:52 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've never compared early to late side-by-side, and can't recall seeing that excellent photo comparison before - thanks for posting that.
I'm struck by the width difference in the engine mounting pads/bases.
IIRC, the engine setback difference from early B to later B K-members is about 1.5"
Buddy of mine who did that swap on an early B said it played hell with the right-side Maxie exhaust manifold at the firewall.
The setback sure seems advisable for some builds, if you're sure the headers/manifolds don't hit the firewall.
Re: '62 B-Body K Member - All V8 The Same? [Re: VITC_GTX] #3205650
01/17/24 03:25 PM
01/17/24 03:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '62 K-member is a one-year-only. V8 works with both SB and BB.
Re: '62 B-Body K Member - All V8 The Same? [Re: John_Kunkel] #3205663
01/17/24 04:02 PM
01/17/24 04:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I liked those 62 mounts if you can still get them. Try using the later k-frame with a Max x-ram, real close to firewall with stock k.
Re: '62 B-Body K Member - All V8 The Same? [Re: cudaman1969] #3205675
01/17/24 04:26 PM
01/17/24 04:26 PM
Plastic mallet on the firewall as needed to help improve on the road performance on M.W. motors with later K members up hammer scope up twocents
Re: '62 B-Body K Member - All V8 The Same? [Re: cudaman1969] #3205678
01/17/24 04:38 PM
01/17/24 04:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Schumacher has the lower brackets, the block brackets and insulators are the same '62-'65.
https://www.engine-swaps.com/products/62-b-body-b-rb-adaptor-brackets
Re: '62 B-Body K Member - All V8 The Same? [Re: John_Kunkel] #3205766
01/17/24 09:03 PM
01/17/24 09:03 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I first bought a 62 Dodge 2 door sedan with the max engine in it. Ugly car racing till I found my 64. I used same mounts off the 64 383 for 426. Later on still having those 62 mounts I decided to put a 383 Super Bee engine in my CJ5, only thing needed was those mounts and 4”x4” 1-4” angle iron bolted to frame. I used a 64 3 speed bell (borg) to mate to the T-85 Borg Warner trans, changed clutch disc to match. Only one hole was off a little so drilled and tapped that one. That CJ5 would SCOOT thru the woods and hills. Sold it to a young kid and he flipped it 8 times, tore it all to heck.
Re: '62 B-Body K Member - All V8 The Same? [Re: cudaman1969] #3205824
01/18/24 09:26 AM
01/18/24 09:26 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
If you move the motor back you'll need to do some additional work, shorten the driveshaft, different trans mount, modify exhaust. Unless you're racing I'm not sure the additional work results in any real benefit.
Re: '62 B-Body K Member - All V8 The Same? [Re: TooMany62s] #3205891
01/18/24 02:09 PM
01/18/24 02:09 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I used the stock '63 K in our '63 330 and I'm glad we did. I need all the help I can get to keep the front end down!
'63 Dodge 330
11.19 @ 121 mph
Re: '62 B-Body K Member - All V8 The Same? [Re: TooMany62s] #3205970
01/18/24 05:05 PM
01/18/24 05:05 PM
You can elongate the trans mount holes or swap the tranny crossmember to the 1966 to 1971 B body style scope wrench up
I recommend sliding the motor back and converting the 1962 to 1964 trans to the 1965 727 tail shaft housing and output shafts you can convert to the later, better and stronger front drive shaft yokes and do away with the OEM ball and trunnion U joints wrench up scope
Re: '62 B-Body K Member - All V8 The Same? [Re: Cab_Burge] #3206124
01/19/24 09:44 AM
01/19/24 09:44 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
A list of the benefits?:
Re: '62 B-Body K Member - All V8 The Same? [Re: TooMany62s] #3206196
01/19/24 01:42 PM
01/19/24 01:42 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Moving the engine back was good when it had no HP
Re: '62 B-Body K Member - All V8 The Same? [Re: TooMany62s] #3206201
01/19/24 01:51 PM
01/19/24 01:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Increased fan/radiator clearance is the main benefit to me. The actual measured setback is 1 5/8".
Re: '62 B-Body K Member - All V8 The Same? [Re: TooMany62s] #3206233
01/19/24 03:10 PM
01/19/24 03:10 PM
More choices on headers is one, #6 spark plug to the fender well clearance, increased air cleaner to hood clearances is another and less weight on the front tires is another, better oil pan choices and so on up
Cudaman, Speaking of HP, how fast have you gone so far?
My quickest run so far at 2860 lbs. was 8.86 at 150.+ MPH in the 1/4 mile, 5.50 at 125. MPH in the 1/8 mile at the same weight in the same car. with a single four barrel using pump E85 boogie grin How about you wave whistling
I'm shooting for mid to low 4 in the 1/8 mile at 170+ MPH in my new heads up no prep car, maybe quicker and faster wrench luck
Re: '62 B-Body K Member - All V8 The Same? [Re: John_Kunkel] #3206234
01/19/24 03:14 PM
01/19/24 03:14 PM
moparx Offline
moparx  Offline
in years [long] past, i beat severely ball & trunion u-joints, with and without good traction, and they held up quite well, as good as the later style 7290 joints.
the only real problem was with the rubber boot cracking or tearing, then spinning out the grease.
they are not the easiest joint to replace, and when one does this, you need to be very precise. the FSM shows how to do it.
then you need to have a good tool to crimp the boot retaining straps on. [think tool used for front drive axle boots]
the 65 and later slip yoke joint solved the issue of difficulty [and time factor involved] in replacing front u-joints.
beer
