Re: '62 B-Body K Member - All V8 The Same?
[Re: VITC_GTX]
#3205560
01/17/24 12:35 PM
01/17/24 12:35 PM
Posts: 31,029 Oregon
AndyF
Bottom picture shows a 1965 V8 K frame if this helps. Top picture is a 1970-71 B body K frame which moves the engine back an inch or so. Both of these K frame are for sale in the classifieds if you're interested in either one.
[Re: A727Tflite]
#3205566
01/17/24 12:43 PM
01/17/24 12:43 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
All V-8’s except Hemi will fit on the same k-frame. There was an early for 62 k-frame that used a can mount - not sure if that applies to them. Thanks!
[Re: VITC_GTX]
#3205650
01/17/24 03:25 PM
01/17/24 03:25 PM
Posts: 25,790 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The '62 K-member is a one-year-only. V8 works with both SB and BB.
[Re: TooMany62s]
#3205891
01/18/24 02:09 PM
01/18/24 02:09 PM
Posts: 4,672 Wichita
GY3
Wichita
If you move the motor back you'll need to do some additional work, shorten the driveshaft, different trans mount, modify exhaust. Unless you're racing I'm not sure the additional work results in any real benefit. I used the stock '63 K in our '63 330 and I'm glad we did. I need all the help I can get to keep the front end down!
[Re: TooMany62s]
#3206201
01/19/24 01:51 PM
01/19/24 01:51 PM
John_Kunkel
Rio Linda, CA
If you move the motor back you'll need to do some additional work, shorten the driveshaft, different trans mount, modify exhaust. Unless you're racing I'm not sure the additional work results in any real benefit. Increased fan/radiator clearance is the main benefit to me. The actual measured setback is 1 5/8".
[Re: TooMany62s]
#3206233
01/19/24 03:10 PM
01/19/24 03:10 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
More choices on headers is one, #6 spark plug to the fender well clearance, increased air cleaner to hood clearances is another and less weight on the front tires is another, better oil pan choices and so on Cudaman, Speaking of HP, how fast have you gone so far? My quickest run so far at 2860 lbs. was 8.86 at 150.+ MPH in the 1/4 mile, 5.50 at 125. MPH in the 1/8 mile at the same weight in the same car. with a single four barrel using pump E85 How about you I'm shooting for mid to low 4 in the 1/8 mile at 170+ MPH in my new heads up no prep car, maybe quicker and faster
[Re: John_Kunkel]
#3206234
01/19/24 03:14 PM
01/19/24 03:14 PM
Posts: 19,402 north of coder
moparx
in years [long] past, i beat severely ball & trunion u-joints, with and without good traction, and they held up quite well, as good as the later style 7290 joints. the only real problem was with the rubber boot cracking or tearing, then spinning out the grease. they are not the easiest joint to replace, and when one does this, you need to be very precise. the FSM shows how to do it. then you need to have a good tool to crimp the boot retaining straps on. [think tool used for front drive axle boots] the 65 and later slip yoke joint solved the issue of difficulty [and time factor involved] in replacing front u-joints.
