Re: Modern take on old T/A ad
[Re: CokeBottleKid]
#3205982
01/18/24 05:58 PM
01/18/24 05:58 PM
Posts: 5,319 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Wonder if that T/A in the ad, still exists? Also I wonder what color it is. Could be white, or Top Banana, or beige.
Plymouth Makes It!
[Re: RoadRunnerLuva]
#3205986
01/18/24 06:15 PM
01/18/24 06:15 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
probably this car. I'd have to dig the brochures out, but the same car, same pics were used for '70&'71, just airbrushed the '71 grill on.
1981 Dodge D150 360 auto
[Re: CokeBottleKid]
#3206369
01/19/24 10:32 PM
01/19/24 10:32 PM
Posts: 6,250 nowhere
Sniper
nowhere
Pursuit planes are what they used to call fighters.
Daytona rake is nose down for better high speed stability. Ever catch air under the car and have the nose lift at 100+, I first experienced it with my Dad in his 72 Buick.
Google is your friend, use it. Gimmicky words for a gimmicky time vocabulary, expand it. Grunting about like a cave man went out with the caveman.
[Re: Sniper]
#3206372
01/19/24 10:42 PM
01/19/24 10:42 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Google is your friend, use it. Gimmicky words for a gimmicky time vocabulary, expand it. Grunting about like a cave man went out with the caveman. My read on the "pursuit plane" comment was related to the similar design of the TA scoop and say a P51 underbelly air scoop, and the other similar aircraft being tasked with pursuit objectives. Regardless, sure gives a lot of merit IMO that these features noted were market driven.
[Re: jcc]
#3206388
01/19/24 11:33 PM
01/19/24 11:33 PM
Sniper
nowhere
Google is your friend, use it. Gimmicky words for a gimmicky time vocabulary, expand it. Grunting about like a cave man went out with the caveman. My read on the "pursuit plane" comment was related to the similar design of the TA scoop and say a P51 underbelly air scoop, and the other similar aircraft being tasked with pursuit objectives. Regardless, sure gives a lot of merit IMO that these features noted were market driven. Yes and the P in P-51 meant Pursuit. The 1st squadron of the Flying Tigers were called the Adam and Eve's, after history's first pursuit.
[Re: FM3AAR]
#3206389
01/19/24 11:35 PM
01/19/24 11:35 PM
Posts: 20,774 A collage of whims
topside
A collage of whims
The T/A scoop could, I guess, be compared to the P-51 scoop... It's about the boundary layer, which of course would matter more at aircraft speeds, but has been applied to racecars as well. In any case, the T/A street car program, as well as the other manufacturers', was about homologating parts, with a big side-helping of marketing.
[Re: Sniper]
#3206403
01/20/24 12:16 AM
01/20/24 12:16 AM
jcc
Bitopia
Google is your friend, use it. Or rear up to gain side pipe needed ground clearance, and call it a "Daytona Rake"?
[Re: CokeBottleKid]
#3206485
01/20/24 01:17 PM
01/20/24 01:17 PM
Sniper
nowhere
It's plenty expanded, stupid vernacular is not worth learning, regardless of the time it comes from. I liken "Daytona rake" and "pursuit plane" to "murdered out" or "turnt" and other zillenial garbage vocabulary. Since those terms come from the WWII era, especially the pursuit mention, your ignorance is astounding.
Historic take on an old T/A ad.
#3206489
01/20/24 01:22 PM
01/20/24 01:22 PM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Wonder if that T/A in the ad, still exists? It does. Also I wonder what color it is. Could be white, or Top Banana, or beige. It is Banana. (Top Banana was used with the 1971 model year)
Re: Historic take on an old T/A ad.
[Re: Alaskan_TA]
#3206604
01/20/24 06:25 PM
01/20/24 06:25 PM
RoadRunnerLuva
Land 'O Lakes
Wonder if that T/A in the ad, still exists? It does. Also I wonder what color it is. Could be white, or Top Banana, or beige. It is Banana. (Top Banana was used with the 1971 model year) Does this car have the '71 grille...and painted front bumper currently, or does it have the chrome and bumperette's, and '70 grille...as in the first ad ?? 🤔
Plymouth Makes It!
