Re: Has anybody run a Mike Jones roller cam in their Mopar?
[Re: Streetwize]
#3205248
01/16/24 01:11 PM
01/16/24 01:11 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I asked about his cams a while back b/c I'd never heard of him. His cams were over double the price of a custom from Dwayne/Comp...if I recall correctly. I was told he's pretty secretive about his grinds, didn't want any specs given out, etc. How true that is, I don't know. I was immediately turned off by the price. Plus I've been so happy w/ every grind Dwayne has spec'd for me...no reason to change.
[Re: Streetwize]
#3205250
01/16/24 01:11 PM
01/16/24 01:11 PM
Posts: 1,145 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I bought one, but ended up selling it before trying it out. Went with the cam Dwayne Porter spec'd & sourced for me, instead. The two cams were pretty different (the Jones cam was smaller) and I'm not sure how they would have compared in performance.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3205274
01/16/24 02:13 PM
01/16/24 02:13 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I believe gregsdart runs one in his bracket race BB.
[Re: fast68plymouth]
#3205337
01/16/24 07:19 PM
01/16/24 07:19 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I have always just ordered my own custom grinds. Always happy with the results thus far.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
#3205362
01/16/24 08:12 PM
01/16/24 08:12 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I believe gregsdart runs one in his bracket race BB. Yes. Inverted flank, .510 lobe, 284 duration at .050 intake, .020 lash with a Jesel 1.7 rocker. Not sure how many grinders now have the ability to grind an inverted flank, and i decided to try it. Exhaust side is 296 @ .050, .019 lash, LSA Is 113. The NET valve lift is .848 intake, .798 exhaust. With the tight lash and high rocker ratio, overlap gets pretty healthy, i am sure. Best peak horsepower of 982 hp was at 110.5 installed and 7600 rpm , but 108 centerline gave gave an increase of horsepower in the midrange of 6200 to 7600, but peak power dropped by 5. This same cam made 926 hp with 440-1 heads and an iron block, all else being the same . The 982 hp combo is 549 cubes, aluminum BMP block, 15/1 compression, .9mm rings, methanol with Terminater, Wilson ported 3x intake, 572-13 cnc 385 heads. The 440-1 headed combo, 2.30 intake valves, 550 cubes iron megablock, 15/1 compression, same intake.
[Re: gregsdart]
#3205451
01/17/24 01:23 AM
01/17/24 01:23 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
We are planning to have Mike grind us a custom cam for our land speed car. It is an oddball vintage engine, so no off the shelf cams or even cores are available. Mike says he can do it. So far, the communication with him has been very brief, he sounds very busy. But he gets back to me within a day or 2. I've only herd good about his cams.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: jwb123]
#3205528
01/17/24 11:20 AM
01/17/24 11:20 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I put a Jones solid roller in my 511 back in 2014. It made the power we expect3d to and wprked excellent on nitrous.
[Re: scottb]
#3205656
01/17/24 03:47 PM
01/17/24 03:47 PM
Posts: 4,457 Washington
madscientist
Washington
Never used his stuff in a Chrysler but back in 2003 we tested a custom Jones cam against a custom Cam Motion cam. Both got the exact same specs to build from. The Jones cam got its doors blown off everywhere in the curve. And it wasn’t close. To hear Jones talk would make one think if you aren’t using his lobes you won’t be competitive because his stuff is that far superior.
I don’t believe it. Now, if someone wants to write the checks I’ll test it again, but I’m not paying for it.
[Re: Streetwize]
#3206159
01/19/24 11:37 AM
01/19/24 11:37 AM
fast68plymouth
So. Burlington, Vt.
One thing I’m quite sure all cam grinders share……..
-Someone thinks they’re the “best”
-Someone thinks a different grinder is better
