Re: Mecum A12 for 70k
[Re: topside]
#3203741
01/11/24 12:32 AM
01/11/24 12:32 AM
Posts: 10,211 Someplace you aren't
SomeCarGuy
I thought a lead seam looked bad and that was the deal, then a few photos later it looks more like the asphalt reflection is making the bottom look weird. The video doesn’t go down far enough to tell anything. Spot under right taillight doesn’t look good. Every decent a12 ive seen in last few years started at 90 and went up to 125 ask if a real Concour type effort. Some more than that.
I want my fair share
[Re: Redbird]
#3203797
01/11/24 11:28 AM
01/11/24 11:28 AM
Posts: 1,674 California
biggE
California
At $ 70K what would be the net to the seller be? Then there’s the hotel plus getting it there. The house made money though. The seller also pays 10% so he got 63k minus auction fees and transportation
[Re: gtx6970]
#3203815
01/11/24 01:33 PM
01/11/24 01:33 PM
Posts: 5,456 Michigan
oldjonny
Don't argue with me.
Auction sites have a way of making almost anything look great in the listing and on your screen. In reality, this thing was more than likely not great and would require a major teardown to expose all of the issues. I did not see it, but guessing there was way more hidden. Gosh, if only I had hung onto my A12 coupe back in the day....But, I did get $1500 for it.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: SomeCarGuy]
#3204000
01/12/24 09:27 AM
01/12/24 09:27 AM
Posts: 1,384 Az
69hemibeep
Az
The A12 has quarter panel disease. You see allot of it where the lower portion of the quarter behind the tire is pulled out to fit the ill fitting aftermarket trunk drop or wheel house. It's even easier to see on Coronet body lines. It should be tucked up under more that the body line in front of the tire.
1969 Hemi Roadrunner 2nd owner
