68-70 B body4 speed console molded carpet? #3203192
01/08/24 12:58 PM
01/08/24 12:58 PM
MN
JERICOGTX Offline OP
MN
What is the trick for applying new carpet, on the driver side hump, that goes on a B body 4 speed console? Does that piece come molded to fit, or is it a PITA?
Suggestions welcome.
Thanks.
69 GTX 68 Road Runner
Re: 68-70 B body4 speed console molded carpet? [Re: JERICOGTX] #3203200
01/08/24 01:27 PM
01/08/24 01:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It comes molded to fit the hump , you need to unroll it and let it sit out somewhere warm for a bit so it will flatten out after being rolled up for however long it has been .
Re: 68-70 B body4 speed console molded carpet? [Re: JohnRR] #3203373
01/09/24 08:43 AM
01/09/24 08:43 AM
MN
MN
Thanks John.
Re: 68-70 B body4 speed console molded carpet? [Re: JERICOGTX] #3203425
01/09/24 01:58 PM
01/09/24 01:58 PM
moparx Offline
moparx  Offline
a small heat gun helps as well.
just use enough heat to allow some extra conformity to be obtained.
too much heat will deform the carpet's pile or loop design.
beer
Re: 68-70 B body4 speed console molded carpet? [Re: JERICOGTX] #3203497
01/09/24 09:30 PM
01/09/24 09:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks.
Hope you didn't buy the 4spd molded console carpet from Classic Industries?....if you did, toss it, piece of crap, buy the 4spd console carpet set from ACC....
Re: 68-70 B body4 speed console molded carpet? [Re: DAYCLONA] #3204295
01/13/24 11:47 AM
01/13/24 11:47 AM
MN
MN
Thanks.
I haven’t bought anything yet. Thanks for the heads up.
Re: 68-70 B body4 speed console molded carpet? [Re: JERICOGTX] #3205808
01/18/24 01:51 AM
01/18/24 01:51 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
link for ACC carpets?
inherited a 69 roadrunner from my grand pop.
Re: 68-70 B body4 speed console molded carpet? [Re: fuelishnsilly] #3205828
01/18/24 09:36 AM
01/18/24 09:36 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
RockAuto
Re: 68-70 B body4 speed console molded carpet? [Re: burdar] #3205841
01/18/24 11:03 AM
01/18/24 11:03 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
What are you'all using to glue the carpet to the console? I am looking to glue carpet on '69 A Body console carpet.
Re: 68-70 B body4 speed console molded carpet? [Re: 69Cuda340S] #3205843
01/18/24 11:12 AM
01/18/24 11:12 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
While not "correct", I used Velcro strips. I didn't have good luck with gluing it. The fit wasn't that good and I needed to make slight adjustments so it fit the floor. The Velcro allowed me to make those adjustments for the best fit.
Re: 68-70 B body4 speed console molded carpet? [Re: burdar] #3205898
01/18/24 02:35 PM
01/18/24 02:35 PM
moparx Offline
moparx  Offline
when using velcro, which is an excellent method to help out the form fit "fit better", use the industrial grade.
the backing adhesive is way better, as is the quality and grip of the "fingers" of the material.
beer
Re: 68-70 B body4 speed console molded carpet? [Re: burdar] #3206043
01/18/24 09:37 PM
01/18/24 09:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
RockAuto
Id deal directly with ACC, seen to many "substitutions" from several vendors pushing stuff off as ACC, best to go directly to ACC's site and purchase, keep in mind the 4spd console kit is available in other ACC carpet grades other than 80/20 loop....cut pile, high cut pile, etc to match the mat'l grade of the main carpet set
MikeG
