Which Hyd Roller Lifter for Small block ? #3199816
12/24/23 12:24 PM
12/24/23 12:24 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I am sure this has been discussed but can't find it in search results. I need a set of reliable hydraulic roller lifters for my street stroker. Who is everyone using ? I'd like to stay under $1000 for the set
Re: Which Hyd Roller Lifter for Small block ? [Re: lostdog] #3199847
12/24/23 02:04 PM
12/24/23 02:04 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Good luck so far with my CompCams 8920-16 pieces.
In fact, I had set them up pretty tight too, that being 1/2" turn for pre-load. The valve springs are CompCams beehive 26056, 150lbs @ seat, and 375lbs @ open, 3/8" pushrods with oil-through provision for my HS rocker arms.
Keep in mind that I only put half a season of cruising on this setup, so this is all preliminary reporting.
Re: Which Hyd Roller Lifter for Small block ? [Re: lostdog] #3199933
12/25/23 03:36 AM
12/25/23 03:36 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Johnson brand, NOT the Hylift Johnson
Re: Which Hyd Roller Lifter for Small block ? [Re: CSK] #3199942
12/25/23 10:14 AM
12/25/23 10:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've had Canes in my 360 for 20 years. Never needed adjustment. Never make noise. The lifter valley needed some grinding on one side of the block for tie bar clearance.
Doug
Re: Which Hyd Roller Lifter for Small block ? [Re: dvw] #3199991
12/25/23 04:14 PM
12/25/23 04:14 PM
AndyF Offline
AndyF  Offline
Crane is long gone and Gaterman (who used to work at Crane) only builds a big block Mopar hyd roller lifter. I don't know why he doesn't offer a SB version since it would be the same body with just a different link bar.
Re: Which Hyd Roller Lifter for Small block ? [Re: AndyF] #3200028
12/25/23 11:16 PM
12/25/23 11:16 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Morel is a option. Hughes engines offers them #5321, USA made. $550
Brian
Re: Which Hyd Roller Lifter for Small block ? [Re: '72CudaRacer] #3200090
12/26/23 02:27 PM
12/26/23 02:27 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Brian
I have used the Morel for both big and small block Mopars with good results. They do work and adjust better with 10w30 oil. Couple sets had a warning sheet about the proper oils to use, they asked for a specific centistoke rating, which I had never heard of. So after doing a little research 10W30 oil is what fits the bill, they actually run quieter with the thinner oil.
