Almost there.
#3199693
12/23/23 06:24 PM
12/23/23 06:24 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Finally have everything together and in the truck. She makes noise. Still some stuff to do like the exhaust eventually. Need to go over the whole truck again to final set alignment 4 link stuff. Do some paint touch ups and the correct and coat the paint itself for now. But its been a long road and its finally just about there. A quick video of the first fire up link below. Enjoy https://youtube.com/shorts/Fs_X1cv3ZLk?si=raeRuSvlWBHzTpQr
Re: Almost there.
[Re: jim sciortino]
#3199822
12/24/23 12:35 PM
12/24/23 12:35 PM
Al_Alguire
Las Vegas
When will the extended video version come to a theater near me??? Im gonna guess never....Or maybe not until I can win another NHRA Championship...
Re: Almost there.
[Re: Al_Alguire]
#3199869
12/24/23 04:37 PM
12/24/23 04:37 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
You be looking good up there in Top Eliminator.... Or just wave at Ryan for me when you go by him.... Cheers and good luck with that ride Al !!!
Bob(Cowboy)Hogan Monrovia So-Cal
Re: Almost there.
[Re: Al_Alguire]
#3199918
12/24/23 09:45 PM
12/24/23 09:45 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
When will the extended video version come to a theater near me??? Im gonna guess never....Or maybe not until I can win another NHRA Championship... Work on it.
Re: Almost there.
[Re: Al_Alguire]
#3199923
12/24/23 10:58 PM
12/24/23 10:58 PM
Posts: 4,733 Moved to N.E. Tennessee
GomangoCuda
When will the extended video version come to a theater near me??? Im gonna guess never....Or maybe not until I can win another NHRA Championship... we'll be rootin for you.
Re: Almost there.
[Re: John Burdine]
#3200082
12/26/23 01:46 PM
12/26/23 01:46 PM
Al_Alguire
Las Vegas
Al, can you give a quick run down on the engine specs? Nothing fancy. A KB Block, 4.625" Bryant crank, Aluminum rods, BME pistons, 55MM Bullet roller, Isky red zone lifters, intake is just port matched deal. Milodon pump, Moroso pan, Jesel Belt drive and distributor. Compression is 15.5-1. Cam is 286/302@.050 lobe lift is .5295"/.5066" on a 115 lobe sep. Carb is a 2.200" Braswell. It is just a bracket deal, well likely more .90 stuff than brackets. Can get into more specifics if anyone likes. FWIW truck has a Glide, sheet metal 9" with 4.29 gear and a 15x33 tire. link strut 6.0 moly chassis. Truck is all steel except front clip. Stock dash and power windows still intact. We still need to build the exhast just waiting on some of the tubing to show up.
Re: Almost there.
[Re: racerhog]
#3200083
12/26/23 01:47 PM
12/26/23 01:47 PM
Al_Alguire
Las Vegas
You be looking good up there in Top Eliminator.... Or just wave at Ryan for me when you go by him.... Cheers and good luck with that ride Al !!! Just a sklow poke. Running S/ST hope I have enough to run 10.90. Maybe a little bracket racing too.
Re: Almost there.
[Re: John Burdine]
#3200101
12/26/23 03:20 PM
12/26/23 03:20 PM
Al_Alguire
Las Vegas
I'm curious as to how well the cast single 4 intake works without extensive porting. This one has not been touched other than a port match and carb pad blending. Something I may do at a later date but for what I am doing with it should work fine. FWIW it makes good power now.
Re: Almost there.
[Re: Al_Alguire]
#3200113
12/26/23 04:06 PM
12/26/23 04:06 PM
birdtracker
I'm curious as to how well the cast single 4 intake works without extensive porting. This one has not been touched other than a port match and carb pad blending. Something I may do at a later date but for what I am doing with it should work fine. FWIW it makes good power now. " It makes GREAT power now the way it is." Al: auto correct kicked in!!!! Birdtracker
