Charlie's SS big block pan #3198434
12/18/23 05:48 PM
12/18/23 05:48 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
The one without the windage tray is mine.
First question, Do they look like E-body application ?
Second, How much oil do these hold ?
Third, So I need some kind of tray. Who might I go to to fab one up ?
Re: Charlie's SS big block pan [Re: hemienvy] #3198441
12/18/23 06:39 PM
12/18/23 06:39 PM
AndyF Offline
AndyF  Offline
I had a bunch of those pans back when Charlie was still around. He used both solid and screen type windage trays. Either one can be fabbed up by a local shop if you need one built.
Re: Charlie's SS big block pan [Re: hemienvy] #3198468
12/18/23 08:27 PM
12/18/23 08:27 PM
Mo.
racerx Offline
racerx  Offline
Mo.
First question, Do they look like E-body application ?....Yes i run that pan in my e-body.
Re: Charlie's SS big block pan [Re: racerx] #3198506
12/19/23 12:41 AM
12/19/23 12:41 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My pan is similar. The difference is a kickout at the side. I fabbed up a second screen tray as he first one cracked. I was told to wrap the ends of the screen around tig wire. Since I've added a scraper as well.
Doug
Re: Charlie's SS big block pan [Re: hemienvy] #3198513
12/19/23 04:53 AM
12/19/23 04:53 AM
I would add a liquid one quart at time with the pan off like now to see where I would want the oil level in that pan not running and use that amount with it running up work scope wrench twocents
you might want to think of making and using a crank scraper also if our looking for the best all out race configuration work twocents
Re: Charlie's SS big block pan [Re: hemienvy] #3198524
12/19/23 09:18 AM
12/19/23 09:18 AM
an8sec70cuda Offline
The Charlie's pan on the left is mine. It is currently installed on my '70 cuda...so yeah, it'll fit an E body, lol.
It holds 8 quarts in just the pan. up
The windage tray is VERY simple. Get a flat sheet of aluminum, bend it on one side, and drill some holes.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Charlie's SS big block pan [Re: an8sec70cuda] #3198537
12/19/23 10:13 AM
12/19/23 10:13 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
8 sec Cuda, I stole your picture when I was looking for a good illustration.
Thanks much for the info. I'm kinda leaning towards a screen of some kind, directional expanded metal maybe.
When you put in the centerlink, do you grease up the pittman arm and the idler arm ?
Hopefully the motor doesn't come out very often.
Re: Charlie's SS big block pan [Re: hemienvy] #3198546
12/19/23 10:49 AM
12/19/23 10:49 AM
No, I just slid everything back in place after I put the pan on and bolted it up. You still have plenty of access to grease all the steering components...if that's what you're asking?
CHIP
Re: Charlie's SS big block pan [Re: an8sec70cuda] #3198547
12/19/23 10:51 AM
12/19/23 10:51 AM
Here are a couple of pics that show the windage tray better...
There is a little small plate at the rear of the windage tray that isn't installed in these pics. It's basically just a tray extension that covers the rear area up.
CHIP
Re: Charlie's SS big block pan [Re: an8sec70cuda] #3198583
12/19/23 12:36 PM
12/19/23 12:36 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Well, what I meant was for ease of disassembly, if required, grease on the tapered stubs on the Pittman / idler,
so they would come apart easier without too much pickle fork hammering.
Re: Charlie's SS big block pan [Re: hemienvy] #3198586
12/19/23 12:40 PM
12/19/23 12:40 PM
No, I just pop them on the side w/ a hammer and they come right apart...no pickle fork.
CHIP
