Re: Charlie's SS big block pan
[Re: hemienvy]
#3198441
12/18/23 06:39 PM
12/18/23 06:39 PM
Posts: 31,051 Oregon
AndyF
I had a bunch of those pans back when Charlie was still around. He used both solid and screen type windage trays. Either one can be fabbed up by a local shop if you need one built.
[Re: racerx]
#3198506
12/19/23 12:41 AM
12/19/23 12:41 AM
Posts: 9,863 MI, usa
dvw
MI, usa
My pan is similar. The difference is a kickout at the side. I fabbed up a second screen tray as he first one cracked. I was told to wrap the ends of the screen around tig wire. Since I've added a scraper as well. Doug
[Re: hemienvy]
#3198524
12/19/23 09:18 AM
12/19/23 09:18 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
The Charlie's pan on the left is mine. It is currently installed on my '70 cuda...so yeah, it'll fit an E body, lol. It holds 8 quarts in just the pan. The windage tray is VERY simple. Get a flat sheet of aluminum, bend it on one side, and drill some holes.
[Re: hemienvy]
#3198546
12/19/23 10:49 AM
12/19/23 10:49 AM
an8sec70cuda
No, I just slid everything back in place after I put the pan on and bolted it up. You still have plenty of access to grease all the steering components...if that's what you're asking?
[Re: an8sec70cuda]
#3198547
12/19/23 10:51 AM
12/19/23 10:51 AM
an8sec70cuda
Here are a couple of pics that show the windage tray better... There is a little small plate at the rear of the windage tray that isn't installed in these pics. It's basically just a tray extension that covers the rear area up.
[Re: hemienvy]
#3198586
12/19/23 12:40 PM
12/19/23 12:40 PM
an8sec70cuda
No, I just pop them on the side w/ a hammer and they come right apart...no pickle fork.
