Twisted Trans Crossmemeber - Common? #3197809
12/15/23 08:35 PM
12/15/23 08:35 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Putting my tranny back in my 67 Coronet race car. The trans crossmember appears to be twisted about 1.5 degrees. Never noticed it before so no idea if always like that or happened due to pounding at the track. I can't fix it, so will make a custom mount to make up the difference in the twist.
Is this common? Should I be worried?
Re: Twisted Trans Crossmemeber - Common? [Re: markz528] #3197816
12/15/23 09:00 PM
12/15/23 09:00 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The driver side crossmember looks smashed in the upward direction? Does it use the 66-67 -style tranmission mount?
Re: Twisted Trans Crossmemeber - Common? [Re: Jeremiah] #3197822
12/15/23 09:19 PM
12/15/23 09:19 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
It does. I have a poly mount. I also have a midplate. Owned the car for 42 years but first time I really see it clearly now that I have a lift. I don't think its smashed. Just a bad picture. No idea how long it has been like this.
Is it a problem?
Re: Twisted Trans Crossmemeber - Common? [Re: markz528] #3197886
12/16/23 09:38 AM
12/16/23 09:38 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
They are all kind of like that. Some straight, some twisted like yours. Body tolerances coming down the line aren't that tight.
Re: Twisted Trans Crossmemeber - Common? [Re: B1MAXX] #3197924
12/16/23 12:10 PM
12/16/23 12:10 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
The thing is that its installed straight. My reference is the area of the crossmember where the frame connectors are tied into. It starts twisting right around where the removable trans mount starts.
I suppose it could have been made that way, but really don't know.
Re: Twisted Trans Crossmemeber - Common? [Re: markz528] #3197937
12/16/23 12:48 PM
12/16/23 12:48 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks to me like someone pried down on it from the rear - looks like buckling where the holes are.
I don't think I've seen that before.
Re: Twisted Trans Crossmemeber - Common? [Re: markz528] #3198032
12/16/23 06:30 PM
12/16/23 06:30 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
I see the nut is not pulled tight to the mount . Could it be possible it is not pushed up all the way . My 63 has this style of cross member & mount . Gary
Re: Twisted Trans Crossmemeber - Common? [Re: markz528] #3198165
12/17/23 04:06 PM
12/17/23 04:06 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do you have a fore/aft limiter ? I used to have problems with transmission mounts until I put a limiter on my car. To me it was a must to keep my clutch adjustment consistent.
Gus beer
64 Plymouth Savoy
Dana 60
