Twisted Trans Crossmemeber - Common?
#3197809
12/15/23 08:35 PM
12/15/23 08:35 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
Putting my tranny back in my 67 Coronet race car. The trans crossmember appears to be twisted about 1.5 degrees. Never noticed it before so no idea if always like that or happened due to pounding at the track. I can't fix it, so will make a custom mount to make up the difference in the twist.
Is this common? Should I be worried?
Re: Twisted Trans Crossmemeber - Common?
[Re: markz528]
#3197816
12/15/23 09:00 PM
12/15/23 09:00 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
The driver side crossmember looks smashed in the upward direction? Does it use the 66-67 -style tranmission mount?
[Re: Jeremiah]
#3197822
12/15/23 09:19 PM
12/15/23 09:19 PM
markz528
Morrow, OH
The driver side crossmember looks smashed in the upward direction? Does it use the 66-67 -style tranmission mount? It does. I have a poly mount. I also have a midplate. Owned the car for 42 years but first time I really see it clearly now that I have a lift. I don't think its smashed. Just a bad picture. No idea how long it has been like this. Is it a problem?
[Re: B1MAXX]
#3197924
12/16/23 12:10 PM
12/16/23 12:10 PM
markz528
Morrow, OH
They are all kind of like that. Some straight, some twisted like yours. Body tolerances coming down the line aren't that tight. The thing is that its installed straight. My reference is the area of the crossmember where the frame connectors are tied into. It starts twisting right around where the removable trans mount starts. I suppose it could have been made that way, but really don't know.
[Re: markz528]
#3198165
12/17/23 04:06 PM
12/17/23 04:06 PM
Posts: 10,553 Rittman Ohio
fourgearsavoy
Rittman Ohio
Do you have a fore/aft limiter ? I used to have problems with transmission mounts until I put a limiter on my car. To me it was a must to keep my clutch adjustment consistent. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
