Re: Entry-level low HP N2O kits? [Re: GY3] #3197137
12/13/23 10:42 AM
12/13/23 10:42 AM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
Wow eek
GY3 - What are the respective 60 / 660 ET & MPH for those different 1/4 passes?
Had to watch this "for informational purposes only", naturally --> https://www.youtube.com/watch?v=7rc5Og8J_4U
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Entry-level low HP N2O kits? [Re: Brad_Haak] #3197151
12/13/23 11:24 AM
12/13/23 11:24 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I wouldn't worry about running too fast at Capitol....put a fogger on it.
Re: Entry-level low HP N2O kits? [Re: Brad_Haak] #3197160
12/13/23 11:57 AM
12/13/23 11:57 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by Brad_Haak
Wow eek
My entire build and documentation thread is here along with slips and they're all there if you want to sift through it. I'm not that good at documenting runs and weather like bracket racers are because I'm just fooling around on Friday/Saturday nights. grin
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/428197/13/my-63-dodge-330-project.html
Off the top of my head, the 250 shot 10.01 was a 1.36 60 ft. with a 6.33 1/8th mile time. The 200 shot it ran 6.49 with a 1.37 60 ft. ( recall the last one distinctly because it had NEVER ran a 6.50 and I entered a 6.50 index that night. It ran a 6.52 on a test pass and first elimination round it ran a 6.49 and broke out by a hundreth! shruggy
'63 Dodge 330
11.19 @ 121 mph
Re: Entry-level low HP N2O kits? [Re: GY3] #3197176
12/13/23 12:48 PM
12/13/23 12:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
From a drag racing perspective, I guess the only downside to Nitrous is if you have a combo with a really loose converter and you're gearing is already "optimized" (just past your power peak at the stripe), you might either have to tighten it up and/or take gear out of it to take full advantage of it.
WIZE
In Car:
Re: Entry-level low HP N2O kits? [Re: Streetwize] #3197466
12/14/23 02:05 PM
12/14/23 02:05 PM
Loudoun County, VA
Loudoun County, VA
Misc thoughts
- I like the idea of a controller to feed it in more gradually
- still feels like something that I could use only in the 1/8 for WOT runs
- suppose the option is there for going from 275/60 to 295/65 to lower the RPM on the big end
- not only are the ring lands "up there" at .175" down from the piston deck, but the gaps aren't intended for big spray either since they're .020/.024 IIRC
Re: Entry-level low HP N2O kits? [Re: Brad_Haak] #3197664
12/15/23 08:29 AM
12/15/23 08:29 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I have this controller:
https://www.summitracing.com/parts/nos-25974nos
It's reasonably priced as far as electronics go, and it's working flawlessly. I used it at Roadkill Nights to ramp in the nitrous over ~1 second. It can control 2 solenoids independently or in unison depending on how you set it up, can use any type of WOT switch as an input, will output a signal to a retard box, and will read RPM from your tach signal so you can have an RPM window on nitrous activation- you don't want to spray it at too low of an RPM, or on the rev limiter. You can also shut the solenoids off after a certain amount of time with the ramps, so if you only wanted to spray to the 8th and shut it off you could do it without having to do anything in the middle of the run, the controller would handle it for you.
I added a transducer for bottle pressure later- you don't need the Holley specific one, it just has to have the correct range.
As GY3 mentioned though- you see the most benefit from spraying as much as you can immediately if the track can take it. My car picks up 1.1-1.2 seconds on a 73 jet (around a 180 shot).
Re: Entry-level low HP N2O kits? [Re: Brad_Haak] #3197677
12/15/23 09:52 AM
12/15/23 09:52 AM
an8sec70cuda Offline
Personally, I wouldn't worry about your current ring gaps for just a 150 shot. I also wouldn't worry about a controller for just a 150 shot. At most, use a digiset timer to delay activation. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Entry-level low HP N2O kits? [Re: Blusmbl] #3197678
12/15/23 09:56 AM
12/15/23 09:56 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
https://www.robietherobot.com/nitrousjetcalculator.htm
Here is a site that has a lot of good information including the temp to bottle pressure ratio. I used to use a small gauge on the bottle (that was junk) and plan on putting a larger gauge and shutoff next to the drivers seat eventually, (getting the pressure off the solenoids as soon as possible prolongs solenoid life) but for now I shoot the bottle with a Fluke IR temp gun and that tells me the temp and pressure the bottle is at. I shoot for 91* typically. I do have the pressure switch that shuts off the heater but still like to monitor temp/pressure.
At the very bottom of the page it has a jet chart that tells you what power to expect (if the plate isn't a restriction) out of a certain size jet. It seems to be pretty accurate in my experience.
'63 Dodge 330
11.19 @ 121 mph
Re: Entry-level low HP N2O kits? [Re: an8sec70cuda] #3197679
12/15/23 09:59 AM
12/15/23 09:59 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
A BB swallows a 150 shot like it's a puff of cold air! grin
'63 Dodge 330
11.19 @ 121 mph
Re: Entry-level low HP N2O kits? [Re: GY3] #3197712
12/15/23 12:02 PM
12/15/23 12:02 PM
Loudoun County, VA
Loudoun County, VA
More misc thoughts...
Current converter may be a little tight for NA, but won't know for sure until track results
A "true" 150 shot would push things to 830-850 HP based on last engine dyno tests; good thing the 8.75 has been replaced by the Strange S-60
This could be a lot of fun... or a really bad idea whistling
Re: Entry-level low HP N2O kits? [Re: Brad_Haak] #3197723
12/15/23 01:24 PM
12/15/23 01:24 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Only unless you get stupid it with it - I ran a lot of nitrous back in the late 80's and early 90's - three stages with two fogger systems and 1 plate system under the carbs - yeah I got stupid with it more than once and paid for it - If you use the jet-able plate system start small work your way up - I always suggest you have a separate fuel pump for the nitrous and use a good controller! it can get real addicting with horsepower in a bottle!
Re: Entry-level low HP N2O kits? [Re: DoubleD] #3197747
12/15/23 03:11 PM
12/15/23 03:11 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have sprayed 250 shots on numerous bone stock vehicles over the years with just backing off timing and good fuel. Never blown up an engine to this day. Even on nitrous.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Entry-level low HP N2O kits? [Re: 6PKRTSE] #3197767
12/15/23 05:44 PM
12/15/23 05:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Just because it sounds like a bad idea doesn't mean it won't be a good time.
