4.10 Pro gears #3196687
12/11/23 01:23 PM
12/11/23 01:23 PM
Byron, NY
W.I.N. Racing Offline OP
Byron, NY
Does anyone remember/know if Richmond made a 4.10 Dana Pro gear for a series 3 carrier??? I have two sets of new/used gears that the original boxes are long gone and I am trying to set up on a 4 series carrier and I have un correctable cross. the Ring gear part number are an 82-XXXX-1 and when I check on line with Richmond it comes back no such number(s)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 4.10 Pro gears [Re: W.I.N. Racing] #3197135
12/13/23 10:29 AM
12/13/23 10:29 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Yes they did I used them in the past in a Dana 60. I don't remember the part number, but the ring gear is really thin.
Re: 4.10 Pro gears [Re: jwb123] #3197189
12/13/23 01:31 PM
12/13/23 01:31 PM
Byron, NY
Byron, NY
Well I bounced my issues off DoctorDiff (Cass) and he came to the same conclusion I had... don't know what to do. So I swapped in another set of the same 82-XXX-1 ring gear part number but the ring gear bolts were bottoming out and the washes trashed so fresh versions are on the way. As an aside, I used to work for the company that invented the Hypoid Ring and pinion and have even held the first Hypoid pinion ever made in my hot little hand. But I left there 17 yrs ago and all my contacts have since left as well. Otherwise I 'd know exactly what these are. Any way, I sent an Email request to Richmond as well as a phone message but no reply to date. Anyone have a set of 8620 (std ) 4.10 gears laying around that would be will to take some measurements for me??? Overall crown height and Root height might reveal some information.
'60 Willys CJ5
