69 B body Suede paint usage? #3196887
12/12/23 08:04 AM
12/12/23 08:04 AM
MN
JERICOGTX Offline OP
MN
Besides, the dash frame, steering column, and upper windshield trim, where else was Suede paint used? Was the ash tray? 3 speaker dash grills?
Thanks.
69 GTX 68 Road Runner
Re: 69 B body Suede paint usage? [Re: JERICOGTX] #3196928
12/12/23 11:18 AM
12/12/23 11:18 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Look in the TSM, it has a full listing of what style paint was used where and the color codes,
Re: 69 B body Suede paint usage? [Re: 6PakBee] #3196941
12/12/23 11:49 AM
12/12/23 11:49 AM
MN
MN
Are the service Manuals online?
Re: 69 B body Suede paint usage? [Re: JERICOGTX] #3196949
12/12/23 12:29 PM
12/12/23 12:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yes, '68-'70 B suede was also used on the ashtray.
If 2-speaker grilles are metal - haven't seen those in a LONG time - they'd have suede.
I have names & #s from a couple of the original paint suppliers if that helps.
But most jobbers either can't or won't be helpful in translating the info to their current product.
Re: 69 B body Suede paint usage? [Re: topside] #3196960
12/12/23 01:40 PM
12/12/23 01:40 PM
MN
MN
paint I have covered. Just need to know everything that should be painted that way.
Re: 69 B body Suede paint usage? [Re: JERICOGTX] #3196963
12/12/23 02:04 PM
12/12/23 02:04 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Re: 69 B body Suede paint usage? [Re: EV2RTSE] #3196998
12/12/23 04:50 PM
12/12/23 04:50 PM
MN
MN
Thanks for that info. Interesting that it says Ash receiver for for suede paint on A bodies, but doesn't list it for B bodies.
Re: 69 B body Suede paint usage? [Re: JERICOGTX] #3197042
12/12/23 07:44 PM
12/12/23 07:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've seen discrepancies for some finishes on those sheets.
So far, I've always had original parts to confirm.
Every single 68-70 B I've owned - more than 15 that I can think of - had suede ashtray paint.
Re: 69 B body Suede paint usage? [Re: topside] #3197116
12/13/23 07:12 AM
12/13/23 07:12 AM
MN
MN
Suede it is then. Thank you very much.
Jeff
Re: 69 B body Suede paint usage? [Re: topside] #3197121
12/13/23 09:21 AM
12/13/23 09:21 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Agreed 6 more here
1969 Hemi Roadrunner 2nd owner
Re: 69 B body Suede paint usage? [Re: 69hemibeep] #3197194
12/13/23 01:47 PM
12/13/23 01:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'll add that the original suede finish had a sandpaper-ish texture and no gloss.
Application should be "dry", if that's an adequate description.
Re: 69 B body Suede paint usage? [Re: topside] #3197398
12/14/23 04:03 AM
12/14/23 04:03 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
And it is very difficult to remove paint shop dust from suede finish. I recently had these painted with OEM suede paint at a paint shop: dash frame, steering column assembly, ash receiver cover, glove compartment door, AND (not mentioned in FSM for Plymouth A body) emergency brake bracket and fastener that attach to the dash frame. The dash frame was left uncovered after paint for a few weeks and accumulated a lot of dust. The only way I could remove it due to the sandpaper-ish texture was with soapy water, high pressure rinse, and blow dry.
On a slightly different topic regarding not suede finish but "Interior Gloss Finish Colors" as opposed to "Exterior Gloss Finish Colors" used in the interior: I believe the factory's use of interior gloss finish colors was a way to save cost by having cheaper paint with lesser ultraviolet protection. Both are exactly the same color - one is just cheaper and less protective than the other. For example, if the upper door frame is green, it is painted exterior F8, but immediately next to it, the quarter panel upper garnish molding is painted interior F8. To keep it simple, I'm using exterior F8 for both.
In the photo, both greens don't look exactly the same after 55 years, but when new, I believe they were the same.
Re: 69 B body Suede paint usage? [Re: kentj340] #3197402
12/14/23 07:16 AM
12/14/23 07:16 AM
MN
MN
The use of suede paint was to keep the glare down on the windshield. Anything shiny in that area would be horrible to look at in bright sunlight. Never understand why people paint dash frames the color of the car...
As for the 2 different colors of F8 Green on the Barracuda, it comes down to different painters. Amount of coverage, different batches, etc. All can make the color different.
I painted my dash frame last night, and am more than happy with how it turned out. I had the dash powder coated black, scuffed it down, and then fogged in 4 coats of Rustoleum Textured Black. OEM perfect? No, but it's close enough for me. I used the correct Suede for my Blue interior, in my Road Runner, and the difference is hard to tell. I'll have to get some pictures out in the sunlight to show the detail.
