69 B body Suede paint usage?
#3196887
12/12/23 08:04 AM
12/12/23 08:04 AM
Posts: 10,039 MN
JERICOGTX
MN
Besides, the dash frame, steering column, and upper windshield trim, where else was Suede paint used? Was the ash tray? 3 speaker dash grills?
Thanks.
69 GTX
68 Road Runner
Re: 69 B body Suede paint usage?
[Re: JERICOGTX]
#3196928
12/12/23 11:18 AM
12/12/23 11:18 AM
Posts: 10,739 North Dakota
6PakBee
North Dakota
Look in the TSM, it has a full listing of what style paint was used where and the color codes,
[Re: 6PakBee]
#3196941
12/12/23 11:49 AM
12/12/23 11:49 AM
Posts: 10,039 MN
JERICOGTX
MN
Look in the TSM, it has a full listing of what style paint was used where and the color codes, Are the service Manuals online?
69 GTX
68 Road Runner
[Re: topside]
#3196960
12/12/23 01:40 PM
12/12/23 01:40 PM
Posts: 10,039 MN
JERICOGTX
MN
Yes, '68-'70 B suede was also used on the ashtray. If 2-speaker grilles are metal - haven't seen those in a LONG time - they'd have suede. I have names & #s from a couple of the original paint suppliers if that helps. But most jobbers either can't or won't be helpful in translating the info to their current product. paint I have covered. Just need to know everything that should be painted that way.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3196963
12/12/23 02:04 PM
12/12/23 02:04 PM
Posts: 1,026 NJ
EV2RTSE
NJ
[Re: EV2RTSE]
#3196998
12/12/23 04:50 PM
12/12/23 04:50 PM
Posts: 10,039 MN
JERICOGTX
MN
Thanks for that info. Interesting that it says Ash receiver for for suede paint on A bodies, but doesn't list it for B bodies.
69 GTX
68 Road Runner
[Re: topside]
#3197116
12/13/23 07:12 AM
12/13/23 07:12 AM
Posts: 10,039 MN
JERICOGTX
MN
I've seen discrepancies for some finishes on those sheets. So far, I've always had original parts to confirm. Every single 68-70 B I've owned - more than 15 that I can think of - had suede ashtray paint. Suede it is then. Thank you very much. Jeff
69 GTX
68 Road Runner
[Re: topside]
#3197121
12/13/23 09:21 AM
12/13/23 09:21 AM
Posts: 1,385 Az
69hemibeep
Az
I've seen discrepancies for some finishes on those sheets. So far, I've always had original parts to confirm. Every single 68-70 B I've owned - more than 15 that I can think of - had suede ashtray paint. Agreed 6 more here
1969 Hemi Roadrunner 2nd owner
[Re: topside]
#3197398
12/14/23 04:03 AM
12/14/23 04:03 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I'll add that the original suede finish had a sandpaper-ish texture and no gloss. Application should be "dry", if that's an adequate description. And it is very difficult to remove paint shop dust from suede finish. I recently had these painted with OEM suede paint at a paint shop: dash frame, steering column assembly, ash receiver cover, glove compartment door, AND (not mentioned in FSM for Plymouth A body) emergency brake bracket and fastener that attach to the dash frame. The dash frame was left uncovered after paint for a few weeks and accumulated a lot of dust. The only way I could remove it due to the sandpaper-ish texture was with soapy water, high pressure rinse, and blow dry. On a slightly different topic regarding not suede finish but "Interior Gloss Finish Colors" as opposed to "Exterior Gloss Finish Colors" used in the interior: I believe the factory's use of interior gloss finish colors was a way to save cost by having cheaper paint with lesser ultraviolet protection. Both are exactly the same color - one is just cheaper and less protective than the other. For example, if the upper door frame is green, it is painted exterior F8, but immediately next to it, the quarter panel upper garnish molding is painted interior F8. To keep it simple, I'm using exterior F8 for both. In the photo, both greens don't look exactly the same after 55 years, but when new, I believe they were the same.
[Re: kentj340]
#3197402
12/14/23 07:16 AM
12/14/23 07:16 AM
Posts: 10,039 MN
JERICOGTX
MN
The use of suede paint was to keep the glare down on the windshield. Anything shiny in that area would be horrible to look at in bright sunlight. Never understand why people paint dash frames the color of the car...
As for the 2 different colors of F8 Green on the Barracuda, it comes down to different painters. Amount of coverage, different batches, etc. All can make the color different.
I painted my dash frame last night, and am more than happy with how it turned out. I had the dash powder coated black, scuffed it down, and then fogged in 4 coats of Rustoleum Textured Black. OEM perfect? No, but it's close enough for me. I used the correct Suede for my Blue interior, in my Road Runner, and the difference is hard to tell. I'll have to get some pictures out in the sunlight to show the detail.
69 GTX
68 Road Runner
