9.25 posi carrier question #3195799
12/07/23 12:09 AM
12/07/23 12:09 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Do 9 1/4 diffs have different carriers depending on gear ratio, that is, ring gear thickness ?
Like Dana 60's ?
Or like Ford 9", just one carrier ?
Re: 9.25 posi carrier question [Re: hemienvy] #3195814
12/07/23 06:49 AM
12/07/23 06:49 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Iirc pretty much all the same except for one oddball to go with a super long ratio from the 70s.
There's some differences in side gears to match a different C clip in the mid 80s.
Angry white pureblood male
Re: 9.25 posi carrier question [Re: ruderunner] #3195815
12/07/23 06:51 AM
12/07/23 06:51 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks, I have a 2.71 ratio gearset. That wouldn't be the oddball would it ?
Re: 9.25 posi carrier question [Re: hemienvy] #3195891
12/07/23 01:26 PM
12/07/23 01:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 2.45 ratio is the odd one.
Re: 9.25 posi carrier question [Re: John_Kunkel] #3195935
12/07/23 05:54 PM
12/07/23 05:54 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thank you gents, sounds like any posi chunk will do !
Re: 9.25 posi carrier question [Re: hemienvy] #3195957
12/07/23 07:50 PM
12/07/23 07:50 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Just watch the c clip sizes, need to match the side gears.
Re: 9.25 posi carrier question [Re: ruderunner] #3204847
01/14/24 11:41 PM
01/14/24 11:41 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
What year truck you dealing with? I have a new carrier Limited slip.
