Flying magnet crank trigger VS dist., ATI magnet damper
#3194756
12/01/23 08:57 PM
12/01/23 08:57 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
I get it with the rear distributor small blocks. But on a Hemi or B/RB with the front distributor, does the crank trigger offer any proven advantage?
Has anybody used the ATI damper with the magnets in the outer ring to eliminate the extra magnet ring bolted on the front and save $$?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Flying magnet crank trigger VS dist., TCI magnet damper
[Re: AndyF]
#3194786
12/01/23 10:37 PM
12/01/23 10:37 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I run a crank trigger with an ATI damper on one of my engines. Yes, it does help as mentioned, seen with a timing light.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#3194788
12/01/23 10:44 PM
12/01/23 10:44 PM
Hemi_Joel
Minnesota
Oops, I meant ATI super damper, not TCI. TCI is the rattler.
Good info, thanks!
[Re: Hemi_Joel]
#3194793
12/01/23 11:02 PM
12/01/23 11:02 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Thanks, Joel The ATI with the magnets is soooo sexy. It's expensive, but that other stuff is so 1980's.
2011 Drag Pak Challenger
[Re: rickseeman]
#3194796
12/01/23 11:32 PM
12/01/23 11:32 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Rock steady. Put a crank trigger on, you will never go back.
I always used a wheel with the magnets in it. No reason not to. Have spare engines, you can just swap the stuff as needed.
[Re: Hemi_Joel]
#3194807
12/02/23 01:09 AM
12/02/23 01:09 AM
Posts: 31,023 Oregon
AndyF
Good info, thanks! Talk to Tim at FHO is you're going to go that way. He should have the correct ATI damper in stock as well as the TDC pointer and trigger pickup assembly. I think I'm the only person that makes those parts although you could also fabricate your own setup. It isn't rocket science, but you do need the pickup in the correct location for the timing to be correct and it does need to be adjustable since moving the trigger is how you change the timing. Rotating the distributor only changes the rotor phasing when you use a crank trigger. https://arengineering.com/home-page/crank-trigger
[Re: CMcAllister]
#3194809
12/02/23 01:12 AM
12/02/23 01:12 AM
AndyF
I always used a wheel with the magnets in it. No reason not to. Have spare engines, you can just swap the stuff as needed. Depends on what is going on in terms of pulley spacing or what else is being driven off the front. There are a lot of reasons to get rid of the magnet wheel such as dry sump engines or engines that don't have much space for pullies.
[Re: mopar dave]
#3194810
12/02/23 01:13 AM
12/02/23 01:13 AM
AndyF
Andy, what is the part number for that bracket? Does it come with the pick up? There are different brackets for different setups and different pickups. I don't sell pickups, you'll have to get them from MSD or Holley depending on which ignition system you are using.
[Re: mopar dave]
#3194872
12/02/23 11:55 AM
12/02/23 11:55 AM
AndyF
The block doesn't matter, the bracket used depends on the timing cover. Billet cover, Jesel cover, etc.
Re: Flying magnet crank trigger VS dist., ATI magnet damper
[Re: A39Coronet]
#3194881
12/02/23 12:58 PM
12/02/23 12:58 PM
Hemi_Joel
Minnesota
I assume the timing locked out with a crank trigger. How does that work out in a street car?
Andy, if the magnets are in the damper, do you make the bracket thinner to compensate?
[Re: Hemi_Joel]
#3194899
12/02/23 02:06 PM
12/02/23 02:06 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Andy, if the magnets are in the damper, do you make the bracket thinner to compensate? Works great. Idles at 800 in gear at a light with the biggest cam.. Throttle response is sharp. Runs great. Might have to use a start retard. Might.
[Re: A39Coronet]
#3194902
12/02/23 02:18 PM
12/02/23 02:18 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
In an NA application, I can't imagine it would make any difference on the time slip. Unless you're running nitrous on the ragged edge, what's the justification for it? Rock steady timing is neat, but if your timing jumps around that much you need a new chain. Chain, gear slop, driveshaft moving around, oil pump affecting the whole mess. Plus cam twist if it's a small block. If you're okay with it moving around a couple degrees, then it doesn't matter. Crank trigger, what you see with a timing light is like a snapshot. Zero movement. With the ignition stuff available now, you can set the base timing ahead of where you want it and dial in a retard curve. Some guys I know are using various amounts of retard at different places on the track. No reason it couldn't be done on the street. Even dialing in the timing precisely on each cylinder, if you are collecting data.
[Re: Hemi_Joel]
#3194925
12/02/23 03:39 PM
12/02/23 03:39 PM
AndyF
Andy, if the magnets are in the damper, do you make the bracket thinner to compensate? I sell a different bracket for that application. Part number is on the website or contact Tim at FHO.
