71 'cuda buildsheet questions... #319415
05/16/09 01:09 AM
05/16/09 01:09 AM
NotRussia
2
2fast4yourBrain Offline OP
Whack top Dodger
Whack top Dodger
2
NotRussia
Fender tag gone, so I have to decipher this buildsheet.
I can BARELY make out an A21 on the buildsheet (Elastomeric Colored Front Bumper Package), but not sure.
However down below, it CLEARLY shows below M71 (Front Colored Bumper).
Would M71 on the buildsheet confirm an A21 option?.
Also, if you had the A62 Rallye Dash, you will ALWAYS get the J25 3-speed wiper option? Hard to make out.
A01 light group...you will then ALWAYS have along with it L31 (Hood/Fender Mounted Turn Signals)??? L25 (Trunk Lamp) clearly shows on the buildsheet, but L31 is worn out.
This is a 383 'Cuda, so I imagine they'd always have N41 (Dual Exhaust )? N42 (Chrome Exhaust Tips) shows on the buildsheet.
Did all 'Cudas some at least standard with R11 (AM Radio (2 Watts))? Or would a radio delete show up w/another code on the sheet?
Sheet is so fragile, I feel like I'm an archaeologist w/the last of the dead sea scrolls.
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319416
05/16/09 01:55 AM
05/16/09 01:55 AM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Also, the buildsheet shows S41 (rear sway bar). Was that part of another option that may show up on a tag? I never seen that.
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319417
05/16/09 02:43 AM
05/16/09 02:43 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Scan it, and use the a copy for your research. Sometimes it is easier to read using a photo viewing program.
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319418
05/16/09 05:33 AM
05/16/09 05:33 AM
OWL
Culvers Offline
Culvers  Offline
OWL
Radios were always an option with a code on tag and BS.
No code = No radio
Culvers
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319419
05/17/09 12:40 PM
05/17/09 12:40 PM
cataclysm80 Offline
cataclysm80  Offline
Not necessarily, I think M71 would be just the front bumper, whereas A21 is the bumper package which also includes other things (dual chrome mirrors, belt molding, maybe also tailpanel blackout?)
I think it DOES work the other way around though. A21 WOULD mean that M71 should be on the sheet.
I think this is true yes.
L31 Is part of the A01 package, but I've often heard that it was left out on cars with performance hoods (at least on challengers). Some cars with performance hoods slipped by and got it anyway. It's hard to say one way or the other, keep researching.
most likely
Radio was not standard on anything. No such thing as radio delete.
You should definitely make a copy of the sheet.
Tav
Re: 71 'cuda buildsheet questions... [Re: cataclysm80] #319420
05/17/09 01:22 PM
05/17/09 01:22 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
In the 71 Cuda coding guide, the color-keyed racing mirrors and color-keyed elastomeric bumper section lists the following footnotes:
Front bumpers-Code A21
Front and rear bumpers-Code A22
I'm not sure on the M71 code, as I find no mention of it.
And yes, the 3-speed wipers were std. with the rallye dash. They are actually referred to as "variable speed". According to the remarks section for J25, variable speed wipers were std. on 440-6 bbl, Hemi, and with codes A04-Basic Group (which could also be on a non-rallye std. cluster), A62-rallye dash, and N96-shaker hood.
Re: 71 'cuda buildsheet questions... [Re: 318 Stroker] #319421
05/18/09 12:26 AM
05/18/09 12:26 AM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Thanks.
Looks like A05 (protection group) appears on the sheet. I never seen that on the fender tag. Anyone seen it?
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319422
05/18/09 12:32 AM
05/18/09 12:32 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I had a 70 Challenger vert that listed A05... But I can't say on a 71 Tag...
Re: 71 'cuda buildsheet questions... [Re: 1_WILD_RT] #319423
05/18/09 12:37 AM
05/18/09 12:37 AM
CT, USA
RM23V1 Offline
RM23V1  Offline
CT, USA
There was no A05 option on a 71 Cuda. The Basic Group was A04 and plenty of them had that.
Or maybe A05 is a build date of October 5?
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319424
05/18/09 09:24 AM
05/18/09 09:24 AM
cataclysm80 Offline
cataclysm80  Offline
Any chance you can scan the sheet and post it? Then we can all help you out.
Tav
Re: 71 'cuda buildsheet questions... [Re: cataclysm80] #319425
05/18/09 02:14 PM
05/18/09 02:14 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Sorry, not a scan, but a picture:
http://img218.imageshack.us/img218/4633/dscf4751.jpg
if you notice in the "A" Combination group, you can see faintly what appears to be:
01, then, 05 (???), then, 21, then 62
I.e. light group, protection group, front rubber bumper, rallye gauge setup.
05 is VERY hard to see, but makes sense since it's coded with V5X (black side moulding), but 05 makes sense.
C16, console has been wiped out, but it appears to be a faint "6" showing.
Below here, you can see M71 shown (M area, 7 column, 1 showing in the cell):
http://img83.imageshack.us/img83/5412/dscf4750e.jpg
Re: 71 'cuda buildsheet questions... [Re: cataclysm80] #319426
05/18/09 02:22 PM
05/18/09 02:22 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
One thing you have to remember is if your car was an non rallye dash car (no A62) you could still get 3 speed variable wipers (J25). Now with A62 Rallye Dash option you always got N85 for the Tach on the broad cast sheet and on the fender tag. Ragtop if you have the Broadcast Sheet there is no problem creating a repro fender tag from that information. The only problem you will have is getting all the crap from members here for doing it.
1971 HEMI E BODY REGISTRY
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319427
05/18/09 03:41 PM
05/18/09 03:41 PM
cataclysm80 Offline
cataclysm80  Offline
Wow! I'll try to take a closer look later, but my first question is the obvious... Does the VIN on the sheet match the VIN/stamped #s on the car?
It's not unusual to find the wrong sheet in a car.
Tav
Re: 71 'cuda buildsheet questions... [Re: cataclysm80] #319428
05/18/09 03:59 PM
05/18/09 03:59 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Tav
Yes yes, that matches the VIN on the door, cowl, rad support, dash pad.
Re: 71 'cuda buildsheet questions... [Re: 2fast4yourBrain] #319429
05/18/09 06:14 PM
05/18/09 06:14 PM
cataclysm80 Offline
cataclysm80  Offline
Thanks, The build date is gone off the sheet, what date is on the door sticker?
Tav
Re: 71 'cuda buildsheet questions... [Re: cataclysm80] #319430
05/18/09 06:48 PM
05/18/09 06:48 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
10-70
