External Oil Pump One Way Valve Mounting
#3193354
11/26/23 08:23 AM
11/26/23 08:23 AM
Posts: 553 Kentucky
clovis
Kentucky
After getting my engine on the run stand and letting it sit a few days between starts, it does seem that it takes 4-5 seconds before it picks up oil pressure so I decided to put in a check valve. Could you guys take a look and see if what I have mocked will work or do I need to take another approach. I thought I remember reading in my other post, that it was beneficial to have it laying horizontal, just worried about the two 90 degree bends.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: External Oil Pump One Way Valve Mounting
[Re: clovis]
#3193356
11/26/23 09:02 AM
11/26/23 09:02 AM
Posts: 2,928 A shed in England
Tig
A shed in England
I tried this way back but the one way valve I used must have been a restriction, I lost around 20 psi when priming with an electric drill. I removed it and never bothered trying anything else, just went to priming with a drill as part of the start procedure. Of course you may have a less restrictive valve but it's worth checking. For info we are using a dual line, I only lose prime after 6 or so days, any time before that, the load is already on the drill. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3193372
11/26/23 10:30 AM
11/26/23 10:30 AM
Posts: 8,887 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
With a check valve you should no longer have to worry about running the line over the pump. You could get away with a much shorter line running it down and under the pump. The check valve shouldn't care what angle its at.
Using the iron cover ... smart move !!!
[Re: Cab_Burge]
#3193454
11/26/23 05:59 PM
11/26/23 05:59 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I wonder if it is that pump combination with a stock cover causing your slow to get pressure Why would that be the cause ?!?!?
[Re: Stanton]
#3193492
11/26/23 09:14 PM
11/26/23 09:14 PM
Posts: 553 Kentucky
clovis
Kentucky
Very good point on being able to able to use a shorter line. I actually have a shorter line with two 90 degree ends. I held it up against the pump and pan and I actually think it may work. It looks like it will have the check valve in a vertical position. If I can get the line to hug the block it should have enough room to where the crossmember isn’t an issue. I will probably try to mock it up tomorrow and post some pictures.
[Re: B1MAXX]
#3193572
11/27/23 10:22 AM
11/27/23 10:22 AM
Posts: 2,665 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Ain't no way I'm putting anything between my pump and its oil. I have to agree with that.
2011 Drag Pak Challenger
[Re: rickseeman]
#3193580
11/27/23 10:57 AM
11/27/23 10:57 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Ain't no way I'm putting anything between my pump and its oil. I have to agree with that. My thoughts too. Maybe a dual line system would be fine, with double the volume capacity to start.
[Re: dart games]
#3193584
11/27/23 11:27 AM
11/27/23 11:27 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
putting a loop in the hose fixes a prime problem If this isn't a loop then please tell us what is !! However with that said, even with a loop all the oil in the loop below that horizontal line will drain back into the pan - very easily and quickly when its hot. What little is left above the pump is all you have to prime with. Then that long loop as to fill up before you have continuous flow and pressure. So while a loop is a good thing, you still want the feed line as short as possible. As for that check valve, its pretty fat - I doubt its very restrictive to normal flow.
[Re: B1MAXX]
#3193643
11/27/23 02:54 PM
11/27/23 02:54 PM
Posts: 170 Sticky South
Rodenteliminator
Sticky South
Put an accumulator on it switch it on while you are cranking, problem solved. Doug
Sorry honey I spent the rent
[Re: B1MAXX]
#3193648
11/27/23 03:03 PM
11/27/23 03:03 PM
gregsdart
The problems come when the oil is thick, clearance in the pump may be too much, or the lines on the intake side are larger external, which provide a lot of dead air before oil is pulled into the pump gears . With a. Wide clearance like i found on my BRAND NEW milodon highvolume pump, even a high speed large drill had a very hard time pulling a prime. Once oul drains off the pump rotors too much leakage by the extra clearance caused my deal much grief. Two hours of hand sanding the aluminum pump body to reduce clearance may help. I sanded it down from .004 to .0017 clearance, which should help a great deal. I will reporrt back.
[Re: gregsdart]
#3193663
11/27/23 04:02 PM
11/27/23 04:02 PM
Posts: 4,575 Motor City
6PKRTSE
Motor City
I have a hoop or loop, however everyone wants to word it on my dual external line pick with no issues. I also run a Accusump as a primer, or preluber.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
