I tried this way back but the one way valve I used must have been a restriction, I lost around 20 psi when priming with an electric drill. I removed it and never bothered trying anything else, just went to priming with a drill as part of the start procedure. Of course you may have a less restrictive valve but it's worth checking. For info we are using a dual line, I only lose prime after 6 or so days, any time before that, the load is already on the drill. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
