Heck the factory will bypass the filter on the pressure side before hurting anything.
The reason I’m not using a filter on my 340, pump feeds straight up to galleys not through all those 90* bends and through a filter that restricts flow. If your pump stops working (0 pressure) let’s see you kill the engine before it blows. By the time it drops it’s already over and gone. Filters are for street cars.
