Worked with an odd 727 today #3192685
11/22/23 05:55 PM
11/22/23 05:55 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
A friend works at a facility that builds turbines. This baby has just been freshened and will be run in on the stand with the trans. Modified push button 727. As you can see the front bell housing is no longer there. No converter. No pump. I went over to figure out the shift cable arrangement on the stand. Pretty cool piece.
Doug
Re: Worked with an odd 727 today [Re: dvw] #3192687
11/22/23 06:21 PM
11/22/23 06:21 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
So for a Chrysler Turbine Car? If not what?
Thanks!
Re: Worked with an odd 727 today [Re: 340Cuda] #3192721
11/22/23 08:53 PM
11/22/23 08:53 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Very Interesting!
Re: Worked with an odd 727 today [Re: 340Cuda] #3192747
11/22/23 10:15 PM
11/22/23 10:15 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Thanks!
Yes one of the 4 running cars.
Doug
Re: Worked with an odd 727 today [Re: dvw] #3192753
11/22/23 10:59 PM
11/22/23 10:59 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That’s awesome! Have you ever seen one of them running in person?
I’ve seen the one at the Henry Ford, and I thought there was one in the Chrysler museum too, but it’s been decades.
Re: Worked with an odd 727 today [Re: Blusmbl] #3192782
11/23/23 02:53 AM
11/23/23 02:53 AM
NY
B1duster Offline
B1duster  Offline
NY
Very cool stuff, I just happened to see this on Facebook
Re: Worked with an odd 727 today [Re: B1duster] #3192855
11/23/23 12:50 PM
11/23/23 12:50 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
I'm 67 years old.When I was I elementary school my class was on a field trip to
somewhere in downtown Cleveland. We were on the highway in a school bus
and I saw a Turbine car. I was so excited,even as a young kid I was always on the
look out for something cool. Can't remember what I had for dinner yesterday,but
I remember seeing that Turbine car so many years ago.
Mike
Re: Worked with an odd 727 today [Re: mkdart] #3192856
11/23/23 12:58 PM
11/23/23 12:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cool stuff you get to be part of for sure.
Re: Worked with an odd 727 today [Re: dvw] #3192881
11/23/23 02:26 PM
11/23/23 02:26 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
That's pretty cool - I hate to even think of what that assembly is worth - almost irreplaceable!
Re: Worked with an odd 727 today [Re: dvw] #3192883
11/23/23 02:35 PM
11/23/23 02:35 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
Wow! Very cool.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Worked with an odd 727 today [Re: cb1289] #3192889
11/23/23 03:02 PM
11/23/23 03:02 PM
moparx Offline
moparx  Offline
thanks for sharing that picture Doug ! up bow
any chance of getting more ?
i have never seen that total assembly out of a car, so i would be very grateful if more pictures would be possible !
beer
Re: Worked with an odd 727 today [Re: cb1289] #3192894
11/23/23 03:22 PM
11/23/23 03:22 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Does Jay Leno still have one
Re: Worked with an odd 727 today [Re: mkdart] #3192960
11/23/23 08:47 PM
11/23/23 08:47 PM
Missouri
randavis Offline
randavis  Offline
Missouri
The bank president in the town I lived close to had one of the cars that they tested. I saw the car around town several times. I never saw an engine though.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI.
New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Worked with an odd 727 today [Re: volaredon] #3193006
11/24/23 12:00 PM
11/24/23 12:00 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Yes I believe he does although I think he "hot started" his and had to have the engine rebuilt. I have seen an article or Youtube video about the process but don't remember which. Hopefully someone else will know.
Re: Worked with an odd 727 today [Re: 340Cuda] #3193102
11/24/23 08:28 PM
11/24/23 08:28 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
This is Jay's powerplant.
Doug
Re: Worked with an odd 727 today [Re: dvw] #3193113
11/24/23 10:01 PM
11/24/23 10:01 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Very cool! I get it not needing a converter but how could it work without a pump?
Re: Worked with an odd 727 today [Re: INTMD8] #3193161
11/25/23 09:34 AM
11/25/23 09:34 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
So It works quite differently. The turbines speed is reduced thru a 10-1 reduction gearbox. The turbine, power steering system, and trans all share the same auto trans fluid for ther lubrication and hydraulics. The turbine has a 900 psi pump that feeds the PS pump. Then it is regulated down to the trans and turbine. The fluid is fed thru the side of the pan to a fixture on the bottom of the valve body. The two valve body inlets for the original pumps (front and rear) are exposed. There is a large windage tray/filter in the pan. Fluid return is filtered when leaving the pan back to the turbine thru a large hose out the side of the pan. There is a hard line connected to the governor test port. This feeds a variable section of the remote pressue pump regultor. The pressures from the governor are used to vary the pitch of a turbine wheel connected to the gear box output shaft. Think of this as the front half of your convertor. The difference is that this wheel sends hot air against an impeller connected to the trans input shaft. Yes it's basicly a convertor that uses air flow like a turbocharger but creates shaft rotation instead of boost. A few thoughts. First two items I didnt understand. I coldn't see since the transmissions (2) there were both fully assembled. The fluid feed doesn't go into the return of the case. Not sure how the trans gets lube to the shafts and planets. Secondly there are no levers in the tail shaft housing that operate park. The pawl and cable lever are not there. The car itself has a park cable, but it does nothing. I talked to a guy from a museum that has a running car. He said park functions with the shifter (which is a lever, not a push button). His park cable is zip tied to the chassis and not connected. So something keeps the car from rolling when ppparked. The brakes are air powerd. So my bet is the air releases them and they are appied without air pressure.
Doug
Re: Worked with an odd 727 today [Re: dvw] #3193248
11/25/23 04:22 PM
11/25/23 04:22 PM
NC
440Jim Offline
440Jim  Offline
NC
I think that is just amazing. A piece of history.
Re: Worked with an odd 727 today [Re: dvw] #3193252
11/25/23 05:01 PM
11/25/23 05:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This is the same concept used in the original factory Clutch-Flite. Aftermarket builders like B&M improved on it by developing the "spider" that drives the pump via the three clutch pressure plate levers.
Re: Worked with an odd 727 today [Re: John_Kunkel] #3193275
11/25/23 07:20 PM
11/25/23 07:20 PM
A727Tflite Online content
A727Tflite  Online Content
I did a Clutchflite a few months ago, here is the backside of the main bulkhead. Using the spider drive makes for a much cleaner installation.
