hemi fuell lines ? #3192559
11/22/23 03:20 AM
11/22/23 03:20 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
does anyone make the stock street hemi type lines from pump to carb in 3/8" tubing ?
stock was 5/16 ,
thank you !
Re: hemi fuell lines ? [Re: calrobb2000] #3192634
11/22/23 02:49 PM
11/22/23 02:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have always just made mine own copying the routing and look from factory photos. You can buy the fittings and junction blocks at most any auto parts stores.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: hemi fuell lines ? [Re: calrobb2000] #3192637
11/22/23 02:59 PM
11/22/23 02:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
Finding the proper size 3/8 inlet fitting for the OEM Carter OEM Hemi carbs may be a challenge work shruggy
I think that Mopar did offer the 1967 SS RO and the Plymouth cars with those fittings and fuel line size on those year 750 CFM carbs on those cars only confused shruggy
Re: hemi fuell lines ? [Re: Cab_Burge] #3192656
11/22/23 04:00 PM
11/22/23 04:00 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I believe I just used the fuel fitting out of some other Edelbrock carbs I had laying around.
Re: hemi fuell lines ? [Re: 6PKRTSE] #3192774
11/23/23 12:46 AM
11/23/23 12:46 AM
s. e. pa.
s. e. pa.
hi ,
what tool do you use to make the close 90 deg bends in the 3/8 line .
bender i have is not the best .
thank you !
Re: hemi fuell lines ? [Re: calrobb2000] #3192786
11/23/23 05:15 AM
11/23/23 05:15 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
These are the ones that I bent up myself for the Edelbrock carbs on the 572 Hemi that I put in the 67 Satellite.
The T-block came from Summit.
Re: hemi fuell lines ? [Re: SNK-EYZ] #3192823
11/23/23 11:12 AM
11/23/23 11:12 AM
VA
dragon slayer Offline
VA
The 66 to 67 had a 3/8" from pump up to T. You may be able to purchase that separate from the manufacturer. The T had center 3/8" but switched to 5/16" to the carbs. So you would only need to make those. The 3/8" double 5/16 is unique but a triple 3/8" more common.
Re: hemi fuell lines ? [Re: SNK-EYZ] #3192970
11/23/23 11:35 PM
11/23/23 11:35 PM
s. e. pa.
s. e. pa.
hi
nice job .
i am trying to copy the factory line set i have in 3/8 so i can use the factory large dome air cleaner .
had a rusel type line front to rear carb but i stuck out from rear carb to far that base would not sit down on carb .
so bend in my lines have closer bends like stock ones , wish i had a bender to make the close bends easy ?
my coil is in stock location also .
waiting on some new fittings now .
heater hose are there also ,
supprised some one does not make this ?
Re: hemi fuell lines ? [Re: calrobb2000] #3192982
11/24/23 07:02 AM
11/24/23 07:02 AM
A Red State
A Red State
I used the chrome dome air cleaner on mine.
The idea was a 572 Hemi that looked basically stock.
Re: hemi fuell lines ? [Re: SNK-EYZ] #3193007
11/24/23 12:12 PM
11/24/23 12:12 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had the same idea because I like the stock look also. Well, sort of.
